SOURCE: i lost the wiring diagram for the 2003 ford windstar spark plugs
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Brown/White
Left Rear Speaker Negative Wire (-): Light Brown/Yellow
Right Rear Speaker Positive Wire (+): Light Brown/Green
Right Rear Speaker Negative Wire (-): Brown/Pink
SOURCE: 1996 Ford Windstar Minivan
The head lights and the fog lights have seperate fuses in the fuse panel under the dash. If the fuse is blown, you might possibly have a short. Hope this helps.
Sound like one of the door jamb switches is bad. Try taking a pencil or screw driver and pushing in on each door switch. Push the switch beyond the "flush" point to see if the switch is just not fully closing.
SOURCE: Windstar Minivan - starts, will not reverse, only forward
Needs a Trans most likely, known to fail around 100k miles. Maintenance very important and correct fluid on these. At the Dealer the price used to be around $2,000.00 , aftermarket shops around half that, FIND a REPUTABLE shop.
SOURCE: Remove the radio in a ford windstar 2000
There is a ford radio removal tool. It looks like a pair of horse shoes most times. Or you can insert four 8 common D finish nails in the four holes (or 4 six D finish nails) -one in each hole until you feel it click. Be gentile. simultaneously push each side towards their respective front door and gently pull the radio out.
