Only if the tablet supports hdmi out. Usually via the usb port or a dedicated mini hdmi port. Check the owners manual or Google the specs for your tablet. If it doesn't you can mirror your tablet however to do so you either need a wifi enabled tv that supports mirroring or a dongle like roku, chrome cast etc. with mirroring capabilities.
The eBay seller is correct.
Your PS 3 has blu-tooth and you would need the usb transmitter for the guitar and usb reciver to plug int the PS3. Did a USB cable come to plug the gutier driectly into the useb port?
Most of these dongles interact with the software drivers installed on your computer. Try reinstalling the drivers for the dongle and if that doesn't work you will need a new dongle.
Plug the dongle in to the USB port, turn on the PS3 and the LED will flash a lot (as if you've pressed the connect button), then press L3 and SELECT together for 3 seconds; it'll then connect.
Then press the PS button.
As long as you keep the dongle plugged in, the controller will not disconnect and won't need pairing again.
