Question about GPS
Tnd 740 keeps telling me " no legal route could be found!" Help please..
Posted by Kerry Hosein on
Need a manual for TND 740 Trucker GPS. can I purchase one from you?
FIXYA doesn't sell manuals.
Here is an internet link that may be the one you need, but unsure.
Let us know using the Comment menu if it is or not.
https://www.randmcnally.com/support/category/tnd-740
Rand McNally TND 740
Oct 05, 2018 | GPS
My rand mcnally 720 tnd said files missing now after connecting to pc its froze at connected
The answer to this question and many others can be found in the FAQ section on our support page at www.randmcnally.com/support. Additionally, for instructional videos on many of the TND & RVND features please visit the Rand McNally You Tube page at www.youtube.com/randmcnallyonline.
To correct the issue please perform a Diagnostics & Repair using the Rand McNally Dock. Step by step instructions can be found at - http://www.randmcnally.com/support/s/diagnose-and-repair
If the Rand McNally Dock does not find an issue with any files, the repair fails, or the Diagnostics & Repair does resolve your issue, please call technical support for additional assistance.
Technical Support is available:
Monday - Friday
7am - 6pm (CST)
1-877-446-4863
[email protected]
Aug 31, 2014 | Rand Mcnally IntelliRoute TND 720 GPS...
Http support gocyberlink com please tell
Sorry, but we do not do that here. You will need to go the legal route to obtain a code.... ask the manufacturer.
Aug 30, 2013 | Computers & Internet
Rand mcnally 710 navi.exe has encountered error
go on lione and do the back up anbd reset to factgory setting it should be ok
Mar 05, 2013 | Rand Mcnally TND 710 GPS Receiver
System file missing on a tnd 710
hi probleme wiht my gps tnd 710 system file missing help me please
Dec 01, 2012 | Rand Mcnally TND 710 GPS Receiver
Tnd powers on but does not go past first screen
Rand McNally has amazingly improved their customer support. Call 800-333-0136. They will try to fix the problem or issue you RMA if your unit is still under warranty.
Feb 05, 2011 | Rand Mcnally TND 500 Car GPS Receiver
Downloaded new update now GPS will not work at all!
Need details... What's not working? The unit doesn't boot up or you can't route because it says your map files are expired?
If it says your map file are expired, you will have to call Ray Allen @ RM Tech Support at 877-446-4863 and have them email you a new navigation.lic file.
It goes in the navi/user folder and reboot. reconnect to computer and delete the bin and layout folders, reboot, reconnect to dock and update it via the TND Dock software.
If that does not work, they will have to send you an SD memory card with a new program on it to install into the TND 500. This will erase EVERYTHING and restore to an "out of the box" condition.
Oct 09, 2010 | Rand Mcnally TND 500 Car GPS Receiver
When i push to calculate route the screen gets stuck on "calculating" and won't do anything.
You have a corrupted trip.db file.
1. connect the TND to the computer and turn the TND on.
2. go to your start menu and press on (my) computer
3. look for an external drive called intelliroute.
4. look on the drive(s) for a folder called Navi
5. double click on the Navi folder.
6. You should see a folder called User.
7. double click on the user folder.
8. You should see a file called Trip.db.
9. left click once on trip.db, then right click and delete.
10. disconnect your TND from the computer and enter a route in.
it should operate fine now.
Thanks,
Mark, Rand Lead Beta Tester
Sep 13, 2010 | Rand Mcnally TND 500 Car GPS Receiver
Check engine light code tcc 740
A tcc 740 is a code for a torque converter clutch problem. This is either the torque converter itself or the control part of the TCC system. dodge's have an issue with transmissions of this generation and in most cases when the code 740 sets, the transmission will need to be replaced.-------
This will help. Thanks please keep updated.please please do rate the solution positively .thank you for using fixya
Mar 20, 2010 | 2000 Dodge Caravan
Keep getting
It means that your unlock file for you map has either been corrupted or deleted. The file needs to be restored. Please see this link for more information:
http://www.sharc.net/discus/messages/6/250.html?1247812497
- Jim
Aug 11, 2009 | Garmin nuvi 205W GPS Receiver
GPS Logo
Top GPS Experts
Marvin
Marvin
Tom Chichester
Are you a GPS Expert? Answer questions, earn points and help others
