Question about GPS
2 thhings 1. ..how to disable credits required display on rockola legend 7000 and 2. how to get to "mapping"
Posted by Mary Lou Hansen on
1 Related Answer
perkins48
Thomas Perkins
  • 14866 Answers
SOURCE: Need owners manual for rockola legend jukebox model 7000
Here's a link for jukebox. http://www.rock-ola.com/Documents/Master_60761-02_2009.pdf
Posted on Mar 24, 2015
What causes a Rockola jukebox not to index?
I might be wrong about this but check inside for a switch marked Scan/off/play inside at the front of the mech. It should be in play position. Also check any circuit breakers and reset them on the upper back of the machine (inside). They look like the clicky end of a ball point pen.
After that I am stuck.
May 16, 2014 | Neonetics Rockola Jukebox Neon Clock
Rockola jukebox keypad doesnt work
If the whole panel is out it sounds like a missing or bad ribbon cable. start there and tell us what happens.
Nov 21, 2013 | Neonetics Rockola Jukebox Neon Clock
Mouse not working on rise of nation rise of legends
I fixed this going to the main folder of the game and in legends.exe (the client launcher) right click -> properties -> compatibility tab -> check the "Disable display scaling on high DPI settings"
Hope it works! good luck
Oct 18, 2012 | Microsoft Rise of Nations: Rise of Legends...
Maps Nav-Cam 7000
try mininova.org or the pirate bay
Good Luck
Jun 08, 2009 | Navigator Evesham Nav-Cam 7000 GPS...
Nav cam 7000
I have an SD card with original maps on it.
Mar 23, 2009 | Navigator Evesham Nav-Cam 7000 GPS...
Garmin Nuvi 610 I've lost all maps :(
If your map detail is missing, then the map information may have been disabled. To check to see if the mapping has been disabled, follow the steps below:
  1. Power the unit ON.
  2. From the Where to? and View Map page, touch the Wrench icon (Tools).
  3. Touch Map.¹
  4. Touch Map Info.
  5. The unit should display the name of the map that is loaded to the unit. The box in front of the map name should have a checkmark in it. If it does not, touch the box to place a checkmark in it.
  6. Touch and hold the back button.
If the map detail is still missing, contact Garmin Product Support at 1-800-800-1020 M-F 8-7cst.
Note:
  1. Some units may require touching Settings before touching Map.
Oct 05, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
Top GPS Experts
Marvin
Marvin
Tom Chichester
Are you a GPS Expert? Answer questions, earn points and help others
