Question about Freezers
Brand new Emerson upright 7cu freezer cools but doesn't freeze. Sounds like water running constantly.
Posted by Jane Doe on
David Spradling
    Top Expert:
  • Freezers Master
  • 12,034 Answers
Bad cooling unit
Posted on Feb 28, 2021
5 Related Answers
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Freezer runs constantly
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
Posted on Mar 03, 2008
Anonymous
  • 1314 Answers
SOURCE: My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
Posted on Sep 11, 2008
Anonymous
  • 11 Answers
SOURCE: My GE upright freezer does not get cold.
Sounds like the system is low on freon. The other common problem is a dirty condenser. Insure the condenser is clean, if it is. You will need to charge the system with freon. Which only a qualified refrigeration tech should do.
Posted on Nov 28, 2008
kachbibi1
Bill Dickerson
  • 979 Answers
SOURCE: problem with upright freezer not freezing
It sounds like the unit is low on freon or the compressor is going bad. You have several other components that could be affecting this as well. Make sure the coils are free from dust and clean underneath. This is a bit premature for you to have problems now, especially since it is a Sears product.
Posted on Feb 17, 2009
larryyb
Larry Youngblood
  • 291 Answers
SOURCE: Kenmore upright freezer alarm sounds constantly
replace the battery in the grill or the hi-voltage control under the unit in the back
Posted on Jul 08, 2009
Why does my upright freezer run constantly but it's not freezing anymore
what you need is a new Compressor,w/o Electricals part number 5304475092
Jan 14, 2013 | Frigidaire 14.1 cu. ft. Upright Freezer...
OLDER G&e UPRIGHT FREEZER PLUGGED IN RUNNING BUT
replace the ptc overload/relay on the compressor and it will cool again
Sep 11, 2011 | GE Freezers
GE Freezer Not Freezing
I am not an expert, but if the defrost heater is not working, then maybe when it was unpluged the coils didn't completly unthaw. If not, the freezer still will not cool properly.
Mar 25, 2009 | GE 13.7 cu. ft. General Electric Upright...
Freezer drain freezes, and constant clicking noise
This clicking noise is a bad relay.
Get it serviced before you run in to a real problem
Jan 29, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Whirlpool upright freezer turning itself off
hi,my name is sourine,i have a probrem with my freezer not cool at all,it's about20 year old.
BRAND WHIRLPOOL
model EV150N A O
14.6 c.f
Dec 19, 2008 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Feb 20, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
FREEZER
If there is no cooling on the evaporator or only partial cooling then you probably have a gas leak, or the compressor is not pumping correctly. Either way you would need a professional diagnosis. Either way not a good scenario. Hope this helps.
Aug 07, 2007 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Dan Webster
Dan Webster
Are you a Freezer Expert? Answer questions, earn points and help others
