SOURCE: alarm clock and time w/ clok smooth ipod system
According to the instructions that we received with our clock. You should be able to get the Instruction manual from [email protected]. It is also supposed to be under the support section of the website www.dpi-global.com but I couldn't find such a link.
However the "Operational Support" insert has the following:
Setting the clock
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
Setting the Alarms
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
SOURCE: setting time and alarm clock for timex nature sounds clock
Hold the time set key in until the time flashes. Now let it go and use the tuning forward and back keys to set the time. I had the same problem because I continued to hold the timeSet button down while trying to adjust it. If you do, the forward/back keys have no effect.
SOURCE: How do I enable the alarm on the Eddie Bauer world
From the normal time position, press Mode and the AL function will come up which is where you set the alarm. Instead of pressing SET, press the up arrow. Each time you press the up arrow it changes function. When the alarm function is on a little bell appears above the colon in the time. The snooze has a ZZ that appears below the colon.The unique feature of this clock, is that it is the only one I have seen where the alarm works in the time zone selected. Most others, the alarm only works the home time zone, not the selected time zone. This is a huge improvement.
SOURCE: Instructions to 'science museum' radio controlled alarm clock
press the alarm button (so the alarm time is on the screen) then the + button. do the same to deactivate the alarm.
it took me forever to work this out after losing my instructions, feel a bit of an idiot now it seems so simple
Travel alarm clocks can have varying
instructions, depending on the type of clock you are using. Here are
some tips for use that will apply to any alarm clock.
