SOURCE: ERROR CODE
it means you have a bod O2 senser the front one as your car has two or three for a v6 but it will be the first one one in the pipe on the front side of a gm product or if your exhaust pipe comes off the back i.e. 2.3 it will be the one in the manifold itself ohh do not forget to check the plug first sometimes an over enthusiastic mechanic unplugs or tampers with these to get you to do more work check the plugs well and wires they are easily fixed
Posted on Jun 14, 2008
SOURCE: error codes
Her is the definition and a list of possiable causes.
Code P1740-Torque converter clutch did not lock up when the PCM sent the command. Enabling conditions: No engine or transmissions codes are present, vehicle speed was under 70 MPH, TPS was under 33% open. When the PCM commanded the torque converter to lock, no change was detected in engine speed. Blocking action: This code can block the following monitors: none.
Testing: Check torque converter solenoid for proper operation.
P1740 TCC O/D SOL PERFORMANCE (GAS)
Theory of Operation
The Torque Converter Clutch (TCC) Solenoid is used to engage the TCC which improves fuel economy.
When Monitored
The Torque Convertor Clutch (TCC) and Overdrive Clutch (OD) will be tested each time the PCM requests TCC engagement in 3rd gear and OD.
Set Condition
The DTC will set if the expected RPM drop is not achieved while attempting to engage TCC or OD. This indicates a malfunctioning torque convertor or overdrive clutch.
Possible Causes
* ENGINE DTCS PRESENT
* TRANSMISSION DTCS PRESENT
* TRANSMISSION TEMPERATURE TOO COLD
* OIL PAN CONTAINS EXCESSIVE DEBRIS
* 3-4 SHIFT SOLENOID
* SHAFT OR SEAL DAMAGE
* TCC SOLENOID
* TORQUE CONVERTER
Posted on Sep 25, 2008
SOURCE: i have error codes p0156 p0161
Check the wire harness near the top of the engine in the rear. They were good for rubbing through on the trans fill tube bracket. Judging by the code you have 4 sensors. you would be interested in the drivers side rear sensor.
Posted on Nov 13, 2008
SOURCE: washer stops mid cycle and displays F 02 error code.
it means that your pump is clogged you need to take that bottom panel off the washer and twist the white cap slowly so it can drain put plenty of towels down once it is done draining pull the cap and clean the trap behind it
Posted on Dec 26, 2008
SOURCE: diagnostic code list for a 1997 *Australian* Toyota Celica
You could try troublecodes.net. Not sure if they have listings for AU vehicles tho. Can't a local Toyota mechanic print them for you? Or try a library if you have access.
Posted on Jun 30, 2009
http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html
Misfire on cylinder 4?
http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html
ABS trouble codes for all models?
http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html
Diagnostic code P0010?http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0010.html-------------Diagnostic Code P1396?
http://howtobyme.blogspot.com/2011/11/diagnostic-code-p1396.html
Code P0452?
http://howtobyme.blogspot.com/2011/11/code-p0452.html
OBD code P0172 on Buick?
http://howtobyme.blogspot.com/2011/11/obd-code-p0172-on-buick-park-avenue.html
DTC Code P0321?
http://howtobyme.blogspot.com/2011/11/dtc-code-p0321-on-buick-park-avenue.html
Error Code P0471?
http://howtobyme.blogspot.com/2011/11/error-code-p0471-on-2007-dodge-ram-3500.html
P0304 Error code?
http://howtobyme.blogspot.com/2011/11/p0304-error-code-on-dodge-neon.html
OBDII scan is receiving NO BUS CODE?
http://howtobyme.blogspot.com/2011/11/obdii-scan-is-receiving-no-bus-code.html
How to Clear OBD error Codes?
http://repairhelpcenter.blogspot.com/2011/11/how-to-clear-obd-error-codes-on-acura.html
Diagnosis and Testing Car Components?
http://vwrepairhelp.blogspot.com/2011/11/diagnosis-and-testing-car-components.html
Diagnostic Trouble Codes list?
Part 1.
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura_18.html
Part 2.------
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura.html
OBD Code is cleared but check engine light will not RESET?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
Diagnostic Code 43 and 71?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-43-and-71-on-1991.html
Code P0132?
http://schematicsdiagram.blogspot.com/2011/12/code-p0132-on-acura-tl.html
P0031 code?
http://schematicsdiagram.blogspot.com/2011/12/p0031-code-on-dodge-dakota.html
How to get diagnostic Code without OBD Scanner on Pre 1995 cars?
http://schematicsdiagram.blogspot.com/2011/12/how-to-get-diagnostic-code-without-obd.html
OBD-II Trouble Code P0300?
http://schematicsdiagram.blogspot.com/2011/12/obd-ii-trouble-code-p0300.html
Getting diagnostic code P0016?
http://schematicsdiagram.blogspot.com/2011/12/getting-diagnostic-code-p0016.html
How to Read Codes from Check Engine Light?
http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
Diagnostic Code P0540 continues to return and the MIL light is on?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0540-continue-to.html
DTC Trouble Code P0401?
http://schematicsdiagram.blogspot.com/2012/01/dtc-trouble-code-p0401.html
Car misfires and error code P0306 and P0303 is shown?
http://technoanswers.blogspot.com/2012/01/car-misfires-and-error-code-p0306-and.html
Diagnostic code P0463?
http://technoanswers.blogspot.com/2012/01/diagnostic-code-p0463-on-ford-f250.html
Check engine light with codes P2195 and P2197?
http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
Diagnostic error code P0121,P0505,P1000,P2101,P2104, P2110,P2135,P2106?
http://technoanswers.blogspot.in/2012/01/diagnostic-error-code.html
P0174, P0037 and P2197?
http://technoanswers.blogspot.in/2012/02/p0174-p0037-and-p2197-on-toyota-rav4.html
P0352 Obd code?
http://technoanswers.blogspot.in/2012/02/p0352-obd-code-on-toyota-rav4.html
Error code p0402?
http://technoanswers.blogspot.in/2012/02/error-code-p0402-on-ford-escape.html
Obd Code P0763?
http://technoanswers.blogspot.in/2012/02/obd-code-p0763-on-lexus.html
OBD code P0301, P0430 and P0174?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0301p0430-and-p0174.html
OBD code P0500?http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0500-on-lexus-rx-300.html
-----------This will help.Thanks.
Feb 23, 2012 | 1997 Chevrolet Astro
For
OBD code problems check the list of help links below. Click the link
below to go through its procedure.
Diagnostic Code P2195?
http://schematicsdiagram.blogspot.in/2012/02/diagnostic-code-p2195-on-toyota-avalon.html
Diagnostic code P1330?
http://technoanswers.blogspot.in/2012/02/diagnostic-code-p1330-on-kia-2wd.html
Diagnostic code P0700, P1330, P1121?
http://technoanswers.blogspot.in/2012/02/diagnostic-code-p0700-p1330-p1121-on.html
shows error code P1330?
http://technoanswers.blogspot.in/2012/02/2003-kia-sorento-shows-error-code-p1330.html
OBD code P1330?
http://technoanswers.blogspot.in/2012/02/obd-code-p1330-on-2003-kia-sorento.html
OBD code P01300?
http://technoanswers.blogspot.in/2012/02/obd-code-p01300-on-toyota-rav4.html
OBD code P0768?
http://repairhelpcenter.blogspot.com/2012/01/obd-code-p0768.html
Evaporative Emissions
System codes details?
http://schematicsdiagram.blogspot.com/2011/11/evaporative-emissions-system-codes.html
Engine Misfire codes?
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
BUS CODE?
Codes?
Components?
list?
Part 1.
list?
Part 2.------
Code P0132?
P0031 code?
P0016?
Check Engine Light?
shown?
P2110,P2135,P2106?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
P0174?
OBD code P0500?
This
will help.
Thanks.
Feb 21, 2012 | 2004 Lincoln Navigator
For
OBD code P1330?
OBD code P01300?
OBD code P0768?
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
BUS CODE?
Codes?
Components?
list?
Part 1.
list?
Part 2.------
Code P0132?
P0031 code?
P0016?
Check Engine Light?
shown?
P2110,P2135,P2106?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
P0174?
OBD code P0500?
This
will help.
Thanks.
Feb 15, 2012 | 2001 Volvo S80
For
OBD code P1330?
OBD code P01300?
OBD code P0768?
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
BUS CODE?
Codes?
Components?
list?
Part 1.
list?
Part 2.------
Code P0132?
P0031 code?
P0016?
Check Engine Light?
shown?
P2110,P2135,P2106?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
P0174?
OBD code P0500?
This
will help.
Thanks.
Feb 11, 2012 | 2003 Nissan Pathfinder
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
Part 1.
Part 2.------
Code P0132?
P0031 code?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
Feb 10, 2012 | 2004 Jaguar S Type
For
OBD code P1330?
OBD code P01300?
OBD code P0768?
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
BUS CODE?
Codes?
Components?
list?
Part 1.
list?
Part 2.------
Code P0132?
P0031 code?
P0016?
Check Engine Light?
shown?
P2110,P2135,P2106?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
P0174?
OBD code P0500?
This
will help.
Thanks.
Feb 09, 2012 | 1998 Lincoln Continental
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
Part 1.
Part 2.------
Code P0132?
P0031 code?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
Feb 04, 2012 | 1997 Nissan Pickup
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
Part 1.
Part 2.------
Code P0132?
P0031 code?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
Feb 01, 2012 | 2001 Chevrolet Tracker
For
OBD code P1330?
OBD code P01300?
OBD code P0768?
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
BUS CODE?
Codes?
Components?
list?
Part 1.
list?
Part 2.------
Code P0132?
P0031 code?
P0016?
Check Engine Light?
shown?
P2110,P2135,P2106?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
P0174?
OBD code P0500?
This
will help.
Thanks.
Jan 30, 2012 | 2003 Ford Ranger Regular Cab
For
OBD code P1330?
OBD code P01300?
OBD code P0768?
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
BUS CODE?
Codes?
Components?
list?
Part 1.
list?
Part 2.------
Code P0132?
P0031 code?
P0016?
Check Engine Light?
shown?
P2110,P2135,P2106?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
P0174?
OBD code P0500?
This
will help.
Thanks.
Jan 28, 2012 | 2004 Ford Focus
23 people viewed this question
