Question about Garden
A sulphated battery and batteries with a bad cell behave like a dead battery but when put on charge will "recharge" quickly, giving an entirely false impression the battery is ok.
Guessing is unreliable and there is no substitute for testing and while there are available very expensive battery testers that give reasonably accurate results the old fashioned method of testing is best - charging, allow to stand for a few hours and then check the cell condition with a hydrometer, checking the terminal voltage and finally using a heavy discharge tester.
It is possible of course, the battery is ok and there is a problem with your ride-on but only proper testing or substituting a good battery will reveal...
Posted on Jan 27, 2021
SOURCE: cub cadet 2140 wont start or turn over
check the cilanoid or the stater , you may also have a lose conaction, try cross jumping the cilanoid
Posted on Aug 16, 2009
SOURCE: ride on mower not starting, battery fully charged,
TAKE A PIECE OF HEAVEY WIRE AND RUN IT FROM THE POSITIVE POST ON THE BATTERY AND TOUCH IT TO THE STARTER POST SEE IF THE STARTER WORKS. IF IT DOES CHECK ALL THE SAFETY SWITCHES ON THE SEAT, DECK , BREAK ECT SEE IF THIS HELPS
Posted on Sep 06, 2009
Testimonial: "Thank you i now know what the faulty part is, excellent tip."
SOURCE: my riding mower won't start. It's a Craftsman
Check your seat switch and brake switch for loose wires.Most likely brake switch do to no spark at plugs,see if PTO switch/lever isnt on.
Posted on Nov 22, 2009
SOURCE: riding mower won't start
clean all your battery connections from battery to starter and selonoid connections and ground cable also where it connects to frame
Posted on Jun 07, 2010
SOURCE: rally ride on lawn mower not starting. briggs and
i have a rally lawn tractor when i hook up the battery it wants to start key is off only thing i did was change the belt. was working fine before .
Posted on Jul 29, 2010
Oct 25, 2016 | Garden
May 14, 2015 | Garden
Sep 01, 2014 | Garden
Aug 23, 2014 | Husqvarna Garden
Jun 22, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Jan 29, 2014 | Bolens 13.5 HP Manual 38-in Riding Lawn...
Nov 19, 2013 | Snapper NXT2346 46" 23HP NXT Lawn Tractor
Oct 17, 2012 | Snapper NXT2346 46" 23HP NXT Lawn Tractor
Aug 03, 2011 | Garden
Aug 27, 2008 | Craftsman Garden
13 people viewed this question
