Question about The Health & Beauty
We just bought a used SunQuest Pro 24RS tanning bed that worked perfectly fine before we brought it home. After getting it home and installing it, the bulbs aren’t turning on but the bed and fan are. Does anyone know what the problem could be? I checked the bulbs to make sure they were weren’t loose and we have adequate power supply. Thank you!
Posted by Kimberly Caldwell on
5 Related Answers
Staci Snell
SOURCE: Where do I find replacement trim profile for my Sunquest Pro 16 SE tanning bed
Ebay has several:http://compare.ebay.com/like/350311266168?_lwgsi=y&ltyp=AllFixedPriceItemTypes&var=sbar
Posted on Mar 02, 2012
skychief2001
Stephen
  • 21873 Answers
SOURCE: sunquest tanning bed wont turn on after not being used for over a year?
you might want to post this in a different section to get an answer
Posted on Aug 17, 2012
emissionwiz
Marvin
  • 85239 Answers
SOURCE: need a manual for esb 16 tanning bed free
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to factory installed systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Posted on Oct 11, 2012
mark d. holman
SOURCE: My Sunquest, Pro 24RS.
ballast is about the only thing left its hard to check anything electrical without a volt meter it could also be the bulb holder
Posted on Feb 09, 2013
Excursia
  • 8 Answers
SOURCE: Sunquest 24 tanning bed fan comes on but bulbs
Sounds like there's a short somewhere. You will probably have to have a pro look at it :)
Posted on Jun 16, 2014
1987 sca 24 series 1tanning bed manual
I have 1987 SCA-24 series 1 wolffsystems tanning bed how do I change the bulbs or where can I get owners manuel?
May 29, 2014 | Wolff Sunquest Pro 24RS 220 Volts
Sunquest pro 16 se
You may have a wire burned out going to that set of ballasts/bulbs. Have a trained technician to check and repair this.
Feb 08, 2013 | Wolff Sunquest Pro 24RS 220 Volts
How to remove and install ballast in sunquest 24 taining bed
I have a question for someone who knows about a Sunquest 24 r tanning bed? Involving bottom bulbs not lighting at all?
Feb 02, 2013 | Wolff Sunquest Pro 24RS 220 Volts
I lost my tanning bed hinges to my sun quest pro 24 rs.
You are better off buying new hinges. Call manufacturer.
Sep 21, 2012 | Wolff Sunquest Pro 24RS 220 Volts
Wiring home tanning bed
If you are installing a bed in your home for the first time, you should have a trained technician to do it, or bad results can happen. Be sure the voltage is correct to the bed - very important. All local wiring codes should be followed for safety - you don't want to kill anyone or the bed.
Sep 02, 2012 | Wolff Sunquest Pro 24RS 220 Volts
2003 SUNQUEST PRO 24RS MANUAL TANNING BED
I Have a m2 24rs8 tanning bed. I loved it . I have moved it was in storage for 2 1/2 years. Moved to a new house. I hooked my bed up. the only thing it does kinda turn the fan on. what have I done wrong....It is on a 20amp bracker. Wire is 12 2 with ground. HELP PLEASE
Aug 25, 2012 | Wolff Sunquest Pro 24RS 220 Volts
Wiring diagram for sunquest pro 24 tanning bed
I do not have a diagram, but the contactors are really simple. You have 2 power switches on top of contactor and 2 wires going to the coil. There should be 4 larger wires on top, 2 in and 2 out.
If any of the crimp-on wire fasteners are blackened, then have a trained technician to replace the fastener. If bed comes on when pushing down on contactor with a plastic ink pen, then check the timer by turning on the timer and checking the voltage at the Main Relay Coil. If no voltage, then the timer is bad.
Jul 31, 2012 | Wolff Sunquest Pro 24RS 220 Volts
Health & Beauty Logo
20 people viewed this question
Top The Health & Beauty Experts
Robert
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
