Question about The Computers & Internet
My print artist platinum 24 is giving me united states sizes for business cards , i need to change it to the united kingdom settings
Posted by margaret holden on
Mahmoud Bedaiwi
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
Hello Margaret,
Try to change the printer default country settings to united kingdom.
Regards,
Posted on Feb 06, 2021
5 Related Answers
Curtis Richner
  • 461 Answers
SOURCE: Printing on templates
This is normally set through the page margins within the software you are using not the actual printer settings. MS Word has templates for various Avery labels, but I've found after loading the template you have to fine tune the margins for your printer. Use plain paper to print test pages and hold them over your card stock to check alignment.
Posted on Dec 12, 2008
Anonymous
  • 6 Answers
SOURCE: It is stating that incorrect paper size and I cannot get it cleared out
Your memory might be too full. Try to delete your memory and see if that will help.
Posted on May 14, 2009
Anonymous
  • 6 Answers
SOURCE: printing a custom size card with a C7280,
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Posted on Jun 27, 2009
Jess
  • 742 Answers
SOURCE: Want to transfer Print Artist 4.0 Platinum by
This simply means that your Print Artist program is no longer compatible with Windows 7. Some of the support files that used to work with XP is no longer recognized in Windows 7.
One way to resolve this is to contact or visit Print Artist's developer's website and search or ask for any windows 7 support or patches for your version 4.0
Posted on Jun 23, 2010
Anonymous
  • 5 Answers
SOURCE: every time I try to boot up print artist platinum
My parents ran into this same issue this afternoon. After a bunch of trial and error over the phone, here's the solution:
1. Go to the Start Menu and open Computer (used to be called My Computer).
2. Browse to c:\Program Files (x86)\Nova\Print Artist Platinum
3. Right-click on Print Artist.exe and create a shortcut
4. Drag the shortcut to the desktop
5. Double-click on the new shortcut to start the application.
6. Delete the non-working shortcut.
Since I was working with my parents over the phone, some of the file names may be slightly incorrect. However, this should be close enough to get you working.
Posted on Jul 17, 2010
My Print artist has stopped working. The Cd rom in my PC is broken so I can't reinstall. What can I do
Print Artist Platinum 24 has stopped working - Fixya
www.fixya.com/.../t13886156-print_artist_platinum_24_stopped_worki...
Aug 4, 2012 - either right click on the setup program and select run as administrator or log in using an administrator account on your PC to install.
Amazon.com: Customer Reviews: Print Artist Platinum 25
www.amazon.com/Nova...US.../B00EPACO3M
Amazon.com, Inc.Find helpful customer reviews and review ratings for Print Artist Platinum 25 at ... Installed this piece of garbage a week ago to start working on a project for a major .... Software performs quite well once the learning stage has been passed.
Support : Nova Development Technical Support
support.novadevelopment.com/
I have a version of Print Artist that came out before version 21. ... When working in the program, it freezes and shows a message "Not Responding" message at the top of ... When exporting a project as a SketchUp file, it has unwanted triangles.
Print Artist Gold 25
Jan 19, 2016 | Nova Development Print Artist Gold 24 no...
My Business Cards
You need to set the print size to match the size of the card.
you either need to resize the document or change your print preferences to match the size of the card.
May 16, 2008 | Avanquest MyBusinessCards (824592)
Www novadevelopment com support
Uninstall your current version of Print Artist, and then install it on a different directory. Also, use Run as Administrator when installing Print Artist. Just to be sure, after you installed Print Artist, right-click on it then Run as Administrator to avoid problems with Windows 7.
Apr 02, 2014 | Computers & Internet
Is Print Artist Platinum Edition version 22 compatible wit Window7?
Print Artist Platinum Edition version 22 is compatible with Win 7.(x86 X64)
You can check this @ Windows 7 Compatibility Center
Hope it helps.
Jun 01, 2011 | Nova Development Print Artist Version 22...
I just replaced my old Printmaster with the 2011 Platinum. I designed business cards using the template from the list. But when I print, the cards are too large to fit on the page. I've tried reducing...
According to your problem you want print a business card and face the with font size & background
colour. It may caused your printer settings.
# First check your paper size in your printer propreties. It must be visiting card size.
# check printing resolution.
# printing quality in printing preferences should be suitable for a card printing.
for your second problem find the background graphics option in your printer properties and set it
properly.
For supported resolution, background image see ith product mannual
Dec 20, 2010 | Computers & Internet
When I press shift and the at @ sign I get "
Your keyboard looks like it is set for the "United Kingdom" instead of the United States. Go to the control Panel > Regional and Language settings > go through each of the tabs and buttons and change the settings to "English-United States" Make sure to change the location to United States and in the keyboard, change that to United States and then remove the "United Kingdom" keyboard, just highlight it and look in the right pane and you will see the remove button. Reboot when you have changed all the settings.
Jul 18, 2010 | Acer NSK8458AN Keyboard
Every time I try to boot up print artist platinum edition it says Print Artist Platinum has encountered a problem and needs to close. What do I need to do to fix the problem?
Jun 29, 2010 | Nova Development Print Artist Version 22...
Want to transfer Print Artist 4.0 Platinum by Sierra from old computer using Windows XP to new computer using Windows 7. Each effort results in a window appearing which states "Run-time error "5".
Jun 23, 2010 | Computers & Internet
When printing business cards, I get an error on the printer. It will print other documents
did you set the paper size to the business card size? if not the machine will expect standard size paper and give you a size mismatch error
Oct 20, 2009 | Brother HL-2170W Laser Printer
When I am making a greeting card and try to print the text the printing is always too light to read.
I FOUND THAT IFI I START WITH CHOOSING THE COLOR AND THEN THE FONTS THE PRINTING IS STRONG COLOR. IF I CHOSE THE LETTERING AND THE SIZE FIRST, THEN THE PRINTED WORK IS UNSATISFACTORY BECAUSE IT IS TOO PALE TO READ.
Jan 26, 2009 | Nova Development Print Artist Version 22...
Computers & Internet Logo
16 people viewed this question
Top The Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
gbob59
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
