Question about Intex Pool & Spa
There are some specialist glues available for this. You will need a good quality flexible adhesive. The spa sides will stretch when inflated so you may need to put on an oversized patch.
Note that some plastic Spas might not be repairable depending on how bad the leak is.
Posted on Feb 04, 2021
SOURCE: goodman furnace leaking water
Yes you can use regular pvc glue. You should use pvc primer before you glue it.
Posted on Jan 21, 2009
SOURCE: I am having difficulty glueing PVC together. I
3M Hot Melt 3764 is the correct adhesive for PVC.
Posted on May 21, 2009
SOURCE: water leaks from the pure source filter
vaseline on filter threads and tighten...thumbs up...
VE6GAR 73 88 99
Posted on Aug 10, 2009
SOURCE: Compool 3600 Spa side remote
Do not reset while the motor is running. Reset the CP 3600 when the power is on but with the motor off. OK.
Posted on Nov 25, 2009
SOURCE: my son's intex has a puncture i have tried the
you must clean the area really well before the glue will stick. first, soap and water the area, then rinse. then, alcohol to wipe clean and dry the water from the area.
then, use cpvc pipe primer (used by plumbers) to clean the area and the inside of the patch.
then, vinyl cement (comes with intex boats) or "seal all" (bought at home depot). apply liberally on both surfaces and hold firmly into place. put a weight ontop if you can to hold the patch. let dry for a few hours. should be good to go.
i've patched my intex mariner about 8 times. patches all hold well.
Posted on Dec 08, 2009
Jun 15, 2018 | Intex Pool & Spa
Oct 06, 2017 | Intex Pool & Spa
Sep 14, 2015 | Intex Pool & Spa
Jun 04, 2015 | Intex Pool & Spa
Jan 22, 2015 | Intex Pool & Spa
Jan 01, 2014 | Intex Easy Set Pool 15x36
Aug 23, 2011 | Intex Easy Set Pool 15x36
Jul 21, 2011 | Intex Easy Set Pool 15x36
May 22, 2011 | Intex "" Metal Frame Pool Set (56998e)...
Mar 29, 2011 | Intex Easy Set Pool 15x36
Dec 23, 2020 | Intex Pool & Spa
It is made of layered vinyl pvc, which according to the local pool co. You would patch it as pvc.
