Question about The Computers & Internet
How to switch back [WASD] back to normal, without using {FN}+W at the same time because that isn't working for my keyboard
Posted by skinny whiteboi on
  • 2 more comments
  • Anonymous Jan 26, 2021
    Hi Skinnyh
    what PC is this, we can not guess PCs yet
    we need deity upgrades for that.
    my guess (wild) is the is some lame
    HP PC, that has that useless mini keyboard,
    there. making gaming keys WASD useless.
    this is normal for that lame keyboard
    the only cure is buy real keyboard,
    even walmart sells them. generic USB keyboads
    buy it and do not use mini
    here is the lame board here.
    SOME DELLS PC HAVE THIS , ODD DUCK KBD.
    next time tell what PC you have. we can not guess. it.
  • Larry Ng
    Larry Ng Jan 26, 2021
    THIS?
    ONE CURE IS GET A REAL; KEYBOARD FOR $10
  • Larry Ng
    some PCs have lame keyboard.
    sold like that.
    tell what PC this is. above is one of the worst made on earth.
    for sure gaming as you are doing
    WASD is gaming keys, we know that.
    left right forward back.
    no gaming pad or joy sticks.
  • Anonymous Feb 20, 2021
    skinny did this guess what PC you have>?
    gaming.
    if yes,what do you think? about that.
    the above keyboard is CRAPPPPPPP
    never ever buy any dell mini with keyboard from H3LL, just go to walmart grab real keyboard and win. win the game too.
    or by K70 like mine.(CHEERY SW, PRIME)
    NOT WITH STANDING, THERE MAY BE KEYBOARD DRIVER HACK THAT CAN FIX THIS. IDK THAT.
    never heard it.
    as you can see that lame kbd is missing the F1 to F12 row of keys.ahhhhh CRAPPPPPPPPPP
    says crusty the clown.
Jarnail Sngh
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
The option to Enable or Disable the use of Fn key is usually available in BIOS -> Advance Settings
https://www.wikihow.com/Disable-the-Function-Key
Posted on Feb 20, 2021
5 Related Answers
Anonymous
  • 903 Answers
SOURCE: keyboard trouble
you need to reload that software that came with the keyboard. Uninstall the keyboard from device manager :- Control Panel>system>device manager. Then reload the software for the keyboard, which should also have the drivers. If you do not have the software, let me know the make and model of the keyboard and I will see what I can do.
Hope this helps
Posted on Oct 28, 2008
Muggs01
Muggs01
  • 72 Answers
SOURCE: fn option appears in place of letters on keyboard
Sounds like you need the keyboard replaced...
Posted on Jan 15, 2009
Anonymous
  • 150 Answers
SOURCE: Fn key on my Asus 1000H seems to be stuck
Press Shift + Numlock key. This will turn off the Fn key and the Fn key will only work when it is pressed, like it is supposed to.
Please rate, thanks!
Posted on Feb 27, 2009
IQUIT
  • 3940 Answers
SOURCE: On a Gateway laptop, the keyboard always
Press Fn Plus the Numlock key that should turn the numlock off
Posted on Oct 05, 2009
Christopher Thrash
  • 425 Answers
SOURCE: Turn on the wireless switch without using without using Fn Key?
  1. Click the "Start" button, then click the "Control Panel" icon on the Start menu. This opens the Control Panel window.
  2. Step 2 Click the "Switch to Category View" link in the left-side pane of the Control Panel window if the window is not already set to category view. You will see the "Network Connections" icon in the right-side pane. Double-click this icon to open the Network Connections window.
  3. Step 3 Right-click the icon for your wireless network adapter in the Network Connections window, then click the "Properties" link in the context menu. This opens the Wireless Network Connection control panel.
  4. Step 4 Click the "Wireless Networks" tab in the Wireless Network Connection control panel. Check the box next to "Use Windows to configure my wireless network settings."
  5. Step 5 Click the "OK" button in the Wireless Network Connection control panel. This completes the process.
Posted on Dec 02, 2009
I need a computer Aires k3 user manual to download
Function Keys
Fn + Esc:4 levels backlit brightness adjustable,suitable for use days & nights
High light - Medium light - Respiration light - Extinguish (High brightness by default when starting up).
7 Multimedia Shortcut Keys: Stop, Fast forward, Rewind, Play/Pause, Volume-, Volume+, Mute
3 levels keyboard speed adjustable:
Fn+F1 : 21 byte per sec(80/S)
Fn+F2 : 30 byte per sec(60/S)
Fn+F3 : 63 byte per sec(40/S)
Fn Multimedia Combination Keys:
Fn + F4 Mute
Fn + F11 Lock/Unlock all keys
Fn + F12 Lock/Unlock Windows Key
FN + W : Switch WASD keys and Arrow keys.
Fn + Tab:3 colors adjustable backlit
Jan 28, 2017 | Audio Players & Recorders
I need a keyboard manual for an Aires K3 seven colour keyboard
Function Keys(for Aires 3 colour keyboard , so i'm guessing will be the same)
Fn + F4 Mute
How can I fix my Zagg keyboard that it writes correctly
configuration keyboard, right country. use usa as standard country
May 03, 2015 | Computers & Internet
Where is num lock key on Dell 5030
If there is no NumLock key then pressing the Fn (Function) buttonshould enable the number pad on the keys that have the Blue numbers onthem. On most laptops (dont know your model) there is a numlock key asthis allows the user to type numbers with two hands and not keep oneholding the Fn button. You would normally press the Fn button and theNumLock option to switch it on and every time you pressed the keys withthe numbers on it would use the number not the letter, pressing the Fnkey with NumLock on would normally allow the letter to be used withouthaveing to disable the NumLock.
This assumes of course that the normal letters are stamped with thenumbers on, if not it is most unusual, I don't think I hav eseen alaptop keyboard without numbers or the NumLock / Fn options. There areUSB number pads available that you can buy, these simply plug in to anavailable USB port and it is like an extension of your keyboard.
Please, please, please, we need to know how we aredoing! Please rate our help to you and leave us a comment so we could go onhelping people like you that need our assistance and expertise! Thank you and, Thankyou for using FIXYA! Bestregards,
Junior
Sep 18, 2011 | Dell Inspiron M5030 Laptop
The keyboard is not working properly on my samsung R519 some keys work but are the wrong letter some keys dont work at all
Mine had the same problem but followed Matthew deSilva's guidance and it helped.........just press (Fn+F11).......PROBLEM WILL BE SOLVED....... :)
May 05, 2011 | Samsung R519-53S Notebook
The keyboard is locked. Instead of letters, it gives me numbers
Click Fn+Numlk as this switches your keyboard to the numbers printed in blue. Pressing that combination again, puts the keyboard back to normal. The Fn key will switch the function keys to the designated lower operation, so your F11 key has the NumLk operation controlled by the Fn key
Jan 23, 2011 | ASUS Laptop Keyboard for Asus Eee PC
My function is stuck on, i cannot type on my keyboard unless i hold the function key down the whole time i am typing. is there such a fn key release function.
Normally, if you hold down the "Fn" key, you'll get whatever character or function is printed in blue on those keys. So holding down the "Fn" key, you now have a numeric keypad in the middle of your keyboard. Release "Fn" and things are back to normal.
Which is exactly the opposite of what the question is asking. The person asking needed to press the "Fn" keys to get the normal, white, characters for each key.
The "problem" is simply that there is a persistent toggle. If you press "Num Lk" (I've also seen it labeled "Pad Lk" for numeric Pad) it turns on the blue keys, and inverts the meaning of the "Fn" key - it's a way to use that embedded numeric keypad without having to hold down the "Fn" key the entire time.
numlk.jpg To fix it, just find and press the "Num Lk" or "Pad Lk" key again. (Note, sometimes these keys are themselves "Fn" keys, so you may, or may not, need to also hold down the "Fn" key to get the right function.) Often there is an indicator light associated with the setting.
Jan 14, 2011 | Computers & Internet
Can`t figure out keyboard on acer aspire one, blue numbers and letters etc Karl
blue number etc are functions that are connected to the blue fn button in the left hand corner.
press and hold the blue fn button and at the some time one of the other buttons.
eg volume + or - for volume up and down or the moon shape for hibernate, or the sun to change the screen brightness,antenna button to switch on and of your bluetoot or wifi, or the screen button to switch on and off your external monitor port on the back etc. the blue number are your numeric keypad like on a normal keyboard this can be used in the same way by holding the blue fn button down at the same time.
I hope this was helpful
Dec 12, 2010 | Acer NSK8458AN Keyboard
Can you tell me how to switch my laptop keyboard
Hold function (Fn) key down and press the key on the top row that has a sign (picture) showing a padlock insde a square. (Num lock key) Normally "scroll" key
Apr 02, 2010 | Gateway 2520915 Keyboard
Acer aspire 5920g keyboard
to switch back to normal typing, press Fn + Scroll Lock or Fn + Num Lock. One of these might work...
Mar 17, 2010 | Computers & Internet
Computers & Internet Logo
22 people viewed this question
Top The Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
gbob59
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
