I have reset it several times, but continues to display lube belt?
It is registering drag, and you haven't lubed the belt. It won't go away until you have performed the maintenance.
SOURCE: horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
SOURCE: lubed belt but display still
After lubrication you have to reset your treadmill settings. Then only the message will go off. To reset the tread mill do the following.
1. Hold the "Stop" button for three seconds to reset the treadmill and clear the current workout selection or screen. The console will reset but will save any accumulated data
2. Press and hold the "eTRAK" button for 10 seconds to reset the console date. This permanently deletes any previously accumulated data
3. Press and hold the "Stop" button while pressing the Speed "+" button. Hold for five seconds to reset the console after applying lubricant to the machine. Lubricant application is usually only necessary when you receive the "LUBE" error
ok
SOURCE: Treadmill Horizon 7900 says Lube Belt
Dear Sir:
I will help you, please do the next step with video, with patience and carefully:
http://www.youtube.com/watch?NR=1&v=KiEZDNe0F8Q
http://www.youtube.com/watch?v=E5aWisfhT3Q&feature=related
http://www.youtube.com/watch?v=KiEZDNe0F8Q&feature=related
WITH THIS YOU WILL FIX IT.
If you need further assistance, please reach me.
Sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
SOURCE: Where does one lube the belt on this treadmill?
Belt is the surface you walk/run on.lift it up in the Centre and spray lube on the board belt runs on
It is necessary to lubricate your treadmill running deck every six months or 150 miles to maintain optimal performance. Once the treadmill reaches 150 miles, the console will display the message "LUBE" or "LUBE BELT". The treadmill will not operate while the message is showing. Hold Stop for 5 seconds to suspend message for 5 miles. Your treadmill came with a bottle of lubricant which can be used for two applications. If you need lubricant, contact Horizon Fitness. Only use lubricant provided by Horizon Fitness.
• Turn off the treadmill with the on/off switch, then unplug the power
cord at the wall outlet.
• Loosen both the rear roller bolts. (For best results, place two removable
marks on both sides of the frame and note roller position). Once the
belt is loosened, take the bottle of lubricant and apply it to the entire
top surface of the running deck. Tighten both rear roller bolts
(matching up the marks for proper position) to original position. After
you have applied lubricant, plug in the power cord, insert the safety
key, start the treadmill and walk on the belt for two minutes to spread
the lubricant.
• Lubricate the air shocks with Teflon based spray.
• Once lubrication is complete, reset the console by pressing and holding 'STOP' and Speed '+' buttons for 5 seconds.
ok
