Error C000 has also been known to be caused by poorly seated or unseated ink tanks. Another method that can be used to try and fix Error C000 is to open the printer door and make sure that all of the printer's ink tanks are properly seated.
Jun 25, 2021
When there is an error code 6000 or C000 on a Canon printer, do not rush to go through the reset or any magic "press button" things. Even if you clear the message, the problem won't go away and the message will reappear. The message 6000 and C000 refer to an obstruction in the printer. Usually something on the way of the carriage unit. It can be a dirty timing strip which needs a cleaning, but most of the times it will just be a pieced of a ripped paper or any other object inside the printer. The tricky part is that it will usually be at one or the other end of the printer. Take yuur flashlight or flashlight app on your phone and shine some light inside your printer. I almost guarantee you that you will find something!
This will apply to all Canon pixma Inkjet printers!
Some are MX922, MX925, MX927, MX928, MG5320, MG5220, MX452, MX870, MX712, MX722, MX892, MX882, MX860, MP620, MP620B, MP630, MP640, MP600, MP800, MP610, MP810, MX950, MG5420, IP7220, IP3000, IP4000, IP4200, IP4300, MX830, MP830, MX452, MX472, MX432, MX452, IP2920, MG5220, MG5120, and many other models.
6A80 6a90 c000 6C10 feeder unit and / or purge unit defective. Blocked Zahnrad-/Kupplungs-Verbindung between the two systems / defective. Troubles with purge pump and or purge tube plugged (clogged). Needs service tech.
I found a solution if you get an error code. I just bought a canon mp620 tonight from Best buy. I followed it to the letter as far as putting the ink in. Closed the lid and it made some God awful noise. The code was C000. You need to COMPLETELY push the ink tanks down underneath their respected sticker letters. Goto www.usa.canon.com look under support. Type in your model number and look under FAQ'S. I also had the error 5100 code. It explains with pictures and instructions what to do. Hope it helps anyone with trouble with the error code c000 and 5100
