Question about The Computers & Internet
SOURCE: need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
Posted on Jan 07, 2009
SOURCE: eMachine MS-7142 board pin connection diagram needed
easy !!!
this is the manual of your motherboard:
http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=173
note that MS-7142 is actually K8MM-V (as you can see the filename of the manual is: M-7142.zip
Posted on Sep 04, 2009
SOURCE: I need a circuit diagram for My Logitech Z-640 Computer Speakers
i have 2.1 channel speaker set it was not working what is the solution
Posted on Mar 08, 2011
SOURCE: Creative Inspire 5300 Volume Control broken!
For those searching the answer "How to replace/repair Creative Inspire 5300 volume control":
Its simple : looking at the back of the suboofer, the pins are as follows from top right, clockwise : LED VDD , Balance pot middle leg, GND, pots + legs, Volume pot middle leg, on switch input. Connect one pots ends to GND and the other ends to pots +, connect a switch on GND and on switch input, anode of led to LED VDD, cathode to GND (there is a 1,8k resistor inside so no external resistor needed)
Posted on Jul 27, 2012
SOURCE: I need the wiring diagram
On that interface what are brown an green for I've been lookin all over
Posted on Aug 22, 2018
May 22, 2014 | Audio Players & Recorders
Jun 23, 2011 | Creative Technology SBS A200 2 Speakers
Jun 10, 2010 | Mitsubishi VS-45607 45" Rear Projection...
Apr 19, 2009 | Creative Labs SBS 370 Computer Speakers
Nov 30, 2008 | PC Chips M848ALU Motherboard
Nov 13, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Apr 03, 2008 | SAMTRON 55V 15" CRT Monitor
Feb 25, 2008 | Dell 3100MP Multimedia Projector
May 22, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Feb 24, 2021 | The Computers & Internet
Feb 23, 2021 | The Computers & Internet
16 people viewed this question
