Question about Kenmore Refrigerators
My Kenmore Refrigerator/freezer model: 111.7302 making fan noise, stops when door is opened starts when door is closed.This unit is only 18 months old. This is bad noise, can be heard all over house.
This started about a month ago, and steadily getting worse.
Posted by Ron Maddox on
Tom Chichester
    Top Expert:
  • Kenmore Master
  • 61,336 Answers
Could be a defective circulation fan
Posted on Jan 25, 2021
SANE AGAIN
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kenmore Master
  • 37,995 Answers
More likely fan is iced up. try defrosting it
Noisy fan in freezer stops when refrigerator doors open not when freezer opens
The noise you hear is more than likely the fan hitting on ice buildup on the coils and you need to replace the "defrost thermostat" located on the coils in the freezer. Here is the part to order.
Here is a video to walk you thru the process. The model may be different but the process is the same.
Keep me posted.
Nov 02, 2012 | Kenmore Refrigerators
My Jenn Air French Door Professional Refrigerator makes a strange annoying knocking sound. It seems to come and go and happens for a few seconds to close to 1 minute. It will stop soon after I open the...
You have two fans and a compressor which could be making the noise. Inside the freezer behind the back cover is the evaporator fan. It probably stops running when you open the door. Hold the door switch down to keep the fan running to see if it's making the noise.
the compressor and other fan is under the unit accessed from the back behind the cardboard cover.
Nov 30, 2009 | Jenn-Air JFC2089HE French Door...
It is making a buzzing noise on freezer side that stops when u open the door but starts again when u close it
On some models of refrigerators, the evaporator fan (behind an access panel at the top of the freezer) shuts off when the door is opened. This fan may be making the buzzing sound.
You should be able to check by pushing in the door switch while holding the door open. The fan should come on; and, if the buzzing resumes, you know what is making the noise. The fan may be developing a problem. If it stops running, the cold air will not be distributed properly between the freezer and refrigerator.
Oct 19, 2009 | Samsung RS2630SH Side by Side Refrigerator
Roaring sound
I have had the same issues. I have owned my LFX25960 for 18 months. All the cooling, noise, and condensation problems are related to 2 fans. One for the freezer/refrigerator compartments and One for the Ice Maker. The fans, apparently, are not sufficient to move enough air through the coils located behind a plastic panel in the freezer compartment. The part numbers for my fans are 1. Ice Maker 4681JB1029E and Refrig/Freezer 4681JK1004E. It is not impossible, but fairly difficult to replace them yourself. You have to remove the large slide out freezer drawer and glides. Then work the back freezer panel loose from the bottom. Be careful not to break it. It is plastic.
Routine maintenance: Pull the refrig out from the wall and blow-out the coils and fan located on the lower right rear. You might find it easier to do this by removing the cover on the lower, back of the refrig.
Apr 17, 2009 | LG LFX25960ST Stainless Steel French Door...
Loud whirring noise that stops when freezer door is open.
It is most likely your circulation fan in the freezer. Normally the fan stops when you open the door. It is a normal operation. Check to make sure that the fan is not blocked by frozen items or that the fan doesn't have an ice build up. On some models the fans stops when you open the door and starts a few minutes later after you close the door.
Mar 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
Zanussi Electrolux frost free fridge/freezer - freezer defrosting
My husband left the freezer door open a couple of months ago, causing ice to form. The loud rattling noise was the fan hitting the ice. The reason why the temperature started to rise but the noise stopped was because the fan had got stuck in a block of ice and was no longer working. Simple solution - defrost the freezer for 24 hours. Touch wood, it is all working fine now!
Aug 29, 2008 | Zanussi ZI921 / 8FF Bottom Freezer...
FREEZER SOUNDS VERY NOISY
It could be the fan is bad or that it is hitting ice. If the noise is kind of a buzzing like it is hitting ice...defrost your unit by unplugging and waiting a day or so for full melt out...then check your door gaskets for cleanliness and good seal. Avoid 'windowshopping".
Dec 22, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
22 people viewed this question
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
