Question about Sharp Televison & Video
SOURCE: Magnavox combo vcr dvd
What you're describing is common when the center LED has failed / gone out. If you're really good at taking a unit like this apart and putting it back together - and not too bad with a solder stick you could attempt this one yourself... It is a pretty intensive repair but not difficult for a good shop just time consuming. The part isn't too expensive either, just an infared LED... In fact, we've run a bit short on stock once in awhile and bought one of the off the shelf versions from Radio Shack which worked just fine. Good Luck Bill
Posted on Jun 12, 2007
SOURCE: DVD Drawer / VHS Eject button
My 1st suggestion is to pull the AC power plug from the wall, wait 5 minutes (have a smoke or a coffee) and plug it back in.
Then retry the functions that are giving you grief.
Report back with the results and we'll go from there.
** Please re-comment if the suggestion did not work for you, there may be several other possibilities.
** Please add a comment before giving a rating Other than Solved
Posted on Oct 18, 2007
SOURCE: How Do I Tune VCR to the TV
I have a panasonic analogue television, and I cannot tune in a Goodman VHS VCR to the television. I have no remote controller for the television, and use the buttons on the front of the set to change stations 1-5. I have however found AV on the television screen and the indication is that the VCR is trying to come through when switched on. I have got a remote controller with the VCR. Can you help me please ??
Posted on Dec 10, 2008
SOURCE: tv/digital converter box & vcr-dvd hook-up
You can find a solution for correct installation on YOU TUBE, How to hook up a converter box to a vcr or dvd. You can access the same video through Google using the key words dvd hookup converter box. Hope this helps
Posted on Mar 04, 2009
SOURCE: I have a Curtis Mathes combo tv/vcr Model CMC13003
I am having the same problem you find out anything?
Posted on Nov 05, 2010
Oct 26, 2015 | Sharp LC-32SB24U 32 in. LCD TV
on Oct 29, 2008 | Sharp 13VT-J100 13 in. Combo
Jul 01, 2009 | Televison & Video
Apr 12, 2009 | Sanyo Televison & Video
Aug 15, 2008 | Sharp VC-A582U VCR
Aug 14, 2008 | Televison & Video
Apr 24, 2008 | Sharp 13VT-K100 13 in. Combo
Mar 16, 2008 | Toshiba 24AF45 24" TV
Nov 19, 2007 | RCA F27242GY 27" TV
Feb 21, 2021 | Sharp Televison & Video
