Question about Sharp Televison & Video
SOURCE: Sharp Aquos LC-37P50E connected to computer with HDMI cable
I got the chat , but some how it got disconnected.
But i would like to help you in this aspect.
HDMI stands for High Definition Multimedia Interface, and supports transmission of both audio and video in high fidelity.
First make sure these things,
Both your computer and your TV will need to support HDMI interface.
It's quite a recent thing in PC graphics cards, so you may have to
resort to S-Video, DVI or VGA for the video, plus a 3.5mm stereo cable (or the optical TOSLINK equivalent) for the sound.
Let know your comments and i will follow up with the suggestions.
Thanx for using fixya,
Good luck.
Posted on Sep 28, 2008
SOURCE: sharp aquos no sound through hdmi
Reset all audio factory setting.Tries unplug,replug it well work,if ur backlight video board it still good.
Posted on Dec 17, 2009
Testimonial: "worked like a charm thank you so much, i was about to throw in the towel and get a new tv, now i don't have to thanks again"
SOURCE: I have HDMI port on back of Gateway. I plugged a
Hello, I have a Gateway DX4300,For the HDMI to be detected you need to power on the device it's conncted to
Posted on Dec 11, 2010
SOURCE: Flickering screen (LC-52SB55u) with HDMI
Do a quick google for this on the AVForums site where you'll find numerous threads covering this problem. First, select the HDMI input before turning on the blu ray player. The handshake over HDMI is the problem. I have the same problem with a Technika blu ray which is fine on my other TVs.
If this doesn't solve it then you ned a firmware update which can be downloaded from Sharp's website and installed using a USB pendrive or by PCMCIA card from Sharp if you have an older model with a rocker on off switch and no USB update port on the back of the TV.
Posted on Jan 09, 2011
SOURCE: Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Posted on Apr 25, 2011
Jul 27, 2016 | Sharp " AQUOS - 70"" Class - LED - 1080p -...
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
Nov 23, 2015 | Sharp Televison & Video
Sep 07, 2014 | Sharp Aquos LC-70LE632U 70 Inch 1080p...
Jun 06, 2013 | Sharp Televison & Video
Oct 15, 2012 | Sharp Aquos Televison & Video
Apr 15, 2011 | Audio Players & Recorders
Sep 11, 2009 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Nov 06, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Feb 21, 2021 | Sharp Televison & Video
13 people viewed this question
