Apex TV. It turns on. Have sound. Why no picture?
Posted by LEONARD KING on
Aron
  • 1,684 Answers
  1. Unplug the TV overnight and then plug it back in and SOMETIMES it could work and fix your issue.
  2. Unplug the TV and everything hooked to it, and then plugging it back in may clear the problem.
  3. Make sure that the TV is set to the correct input.
  4. If the TV screen still remains dark unplug your TV and push the power button for about one minute and then plug it back in. See if that resets your TV. If it still remains dark use a flashlight and angle it against the screen with the TV at a station where you can hear the sound See if you can make out shadows or shapes
Posted on Feb 06, 2021
5 Related Answers
Anonymous
SOURCE: no picture or sound?
hi i have a 42 inch plasma samsung tv i have picture and no sound
Posted on Nov 16, 2008
snakehead
Henry Thomas
  • 1074 Answers
SOURCE: Apex TV AT2002 has sound and no picture.
i am not familiar with your tv but i can say that there is a micro that control most functin of your tv,have a tech check your tv for repair
Posted on Jul 12, 2009
Derrick Buckles
  • 74 Answers
SOURCE: have an apex tv model #At3208s, no picture sound
Hi
this sounds like a short on the ht(B+ line) out of the power supply most likely causes are a s/c line output tranistor or a faultry flyback transformer
Regards windyhouse
Posted on Mar 29, 2010
davemaurer
Dave Maurer
  • 84 Answers
SOURCE: how to change a bulb in a apex pf2720 tv
I'd guess it is not a bulb issue if the audio also stopped working. Check your input source, connections and the like. Try using a different input (ie input 4 or the front AV connectors) and a different source (ie your old Nintendo instead of your DVD player).
Posted on Nov 17, 2011
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: apex LD4088 no picture
The inverter is the usual suspect with that symptom. It may be hard to find a replacement inverter for an apex model. But you might be able to get one from www.tvrepairworld.com
Posted on Oct 30, 2012
I'm hooking up an APEX Digital TV and when playing a DVD, the picture is fine, but there is no sound. When on TV mode, sound is fine. Suggestions on how to fix this?
  • Turn everything off. Turn on TV and Select dvd input (Source). Wait 10 or so seconds. Turn on DVD player. Works for me with similar problem. Good luck -
  • John
Jan 17, 2016 | Apex Digital Televison & Video
Apex gt 2715 turns on but no picture or sound
Its main digital board should be suspected. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact any experienced service technician, or the nearest service center.
Mar 13, 2013 | Apex Digital Televison & Video
I have a 8 years old apex tv. while watching tv the picture went out but it still has sound. i can't see the channel numbers or volue bar is it worth fixing
I WOULD SAY NO ! THE PICTURE TUBE IS PROBABLY AS MUCH AS THE TV IS WORTH. i had a very nice sony trinatron tv. the picture tube whent on it at about 5 years so I CALLED FOR REPAIR AND THE PICTURE TUBE WAS 2-300 DOLLARS. good-day !
Jan 20, 2012 | Apex Digital Televison & Video
I have an apex 4088,have had it for 5 months.Suddenly I only have sound,no picture
Hello
If sound is OK and there is no picture, means the video processing section of your Apex TV is faulty. It may be either to the absens of voltage or a damaged processor IC inside the circuit board. Being a new set, it will have guarantee. If it is in guarantee period, get it service by the Authorised Service Center for Apex. The processor board costs some more. Do not open it, if guarantee prevails even now. Opening the set for any purpose will void the guarantee. OK.
Jul 05, 2011 | Apex Digital LD4088 LCD TV
My 40" apex tv does
dude replace either power supply board or backlight inverter board, get them on shopjimmy for under $100.00 dollars both.
Dec 31, 2010 | Apex Digital AVL3076 30 in. HD-Ready LCD...
Have an apex tv model #At3208s, no picture sound just chirping sound when plugged in and power turned on! should i repair or just buy another one?
Hi
Regards windyhouse
Mar 29, 2010 | Apex Digital AT3208S 32" TV
Jul 12, 2009 | Televison & Video
No picture or sound?
Nov 03, 2008 | Televison & Video
I get sound but no picture on my apex at2402.
if there's a channel and volume display but no picture,the problem of your tv is ABL..it is a resistor value from 10K ohms up
Oct 10, 2008 | Apex Digital AT2402 24" TV
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
