Question about Car Audio & Video
SOURCE: audio wiring problem
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown (or your own wire to a metal grounding point)
Illumination Green
Antenna Trigger Black/Red
Front Speakers 4" Dash
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Green
Right Front (-) Blue
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) Black
Left Rear (-) Yellow
Right Rear (+) Red
Right Rear (-) White
I a '83 camry, there are 2 seperate plugs that go into a factory radio.
One for Power/and front speakers, and the other for rear speakers.
Sounds as if you are missing part of the harness for the rear speakers (or it is shoved in the back of the dash unused by the previous install). If there is not an un-cut plug in the dash - your only course of action would be to run your own set of speaker wire to the rear.
See this picture... these are the plugs that should go into your factory radio....
Metra kit 71-1938 will go from your factory wiring directly into your factory radio.
Thanks for using FixYa - a FixYa rating is appreciated for my effort in answering this Freebie question.
Posted on Feb 25, 2009
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: White/Red
Radio Ground Wire: Black
Radio Illumination Wire: n/a
Radio Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Rear Glass
Front Speakers Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Posted on Apr 06, 2009
SOURCE: wiring after market stereo to factory wiring equipt with factory amp
you have to get the cable that conects your factory deck harness to the aftermarket deck, and that will allow you to use your factory speakers and amp, the wire harness is availiable at canadian tire or any stereo shop
Posted on May 06, 2009
SOURCE: Need a wiring color code for the 2000 Hyundai
Go to www.hmaservice.com and register( Vehicle by VIN). Afterward, you have access to shop manuals, service bulletins, wiring diagrams, etc. about your vehicle.
Posted on Nov 04, 2009
SOURCE: 2006 hyundai santa fe stereo wiring color code
I was given two Lanzar 6.5 and two Pioneer 6.5 speakers. There is nothing wrong with my stock speakers, I just wanted to add a little more thump and clarity. I took off the front drivers side interior panel, Which wasn't all that bad, but i'm having major problems putting it back together. I'll get into that a bit later. I figured swapping the old for the new would be simple. Being it has two wires (pos/neg) going to the driver/speaker cone and two wires going to the tweeter portion that goes over the lower part, four wires total. The wires are White, Brown, yellow, and Black going into a black clip, then they turn black coming out the other side. I cut the four after the clip. My new speakers have only two posts to accommodate the driver and tweeter. So I left off the two for the tweeter and it sounded awful. I tried combining the two positive and two negative and hooking it up that way. That too sounded awful. The tweeter was squealing and chirping. I tried every configuration. They all sounded like ***. What am I doing wrong. I know people swap out stocks for after market all the time. I wanted to be sure my new speaker wasn't defective, so I tried all four (Both brands) with the same results. So I gave up and put the original back in. It sounds fine, just like it had before. But now I can't put the door panel back on. I know it's just tricky and i need more patience. I'm so bummed. I have these great speakers and have no idea why I can't install them. Do I need some aftermarket clip? It seems so easy, why is it so flappin hard? I've done this with other cars in the past with no issues. This four wire thing is killing me... Please HELP ME!!!!!!!!
Posted on Jan 24, 2011
Sep 03, 2018 | Metra Car Audio & Video
Jan 20, 2014 | Car Audio & Video
Feb 18, 2011 | Ford Explorer Cars & Trucks
Sep 24, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
Jul 27, 2010 | Kicker Car Audio & Video
Jan 18, 2009 | 1997 Dodge Dakota
Nov 11, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Aug 10, 2008 | Clarion Car Audio & Video
Jan 23, 2008 | Audio Players & Recorders
Jul 01, 2007 | Sherwood XCM-6870R CD Changer
18 people viewed this question
