The screen blinks (as well as all the inside lights we see thru the vents in back)
SOURCE: TV SCREEN GOES BLANK
Yes your inverter is bad, I have the same problem my set is about 1 and 1/4 years old. Because Olevia makes a terrible product there inverters are attached directly on to the panel, which means they will only sell the inverter along with the panel i.e $700+ to replace + $100 dollars labor if u don't know how to fix it ur self. I am currently searching to find the manufacture that makes the inverters because olevia will not disclose that information. I believe it is darfon, if so the inverter should cost about $150-200 depending. If you dont believe you can fix it ur self ur best bet is try and sell the set for scrap take ur $100 or so dollar and buy a quality product! Oh and dont call there support they will tell 10 different things before u find out this long for seen truth!
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
SOURCE: power light flashing three times. when came on screen was distort
very common problem you need to replace the flyback number 259296 and the CP150 you can get replacemnent flyback and cp150 at the following link with free step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/
SOURCE: continued from no picture no sound just clicking
HI, this is total power supply failure. you and a dual power supply unit that, universally, powers all devices directly. there are no ballast in this set so, you will have to replace the Power controls and the fly-back transformers as well. this will fix this unit.
