The CT877 remote was included with several Toshiba TVs, including the 26DF56. Thus the programming codes for the remote are in the TV manual on pages 16-17. This manual is available on the support page: https://support.dynabook.com/support/staticContentDetail?contentId=2844172&isFromTOCLink=false . The current link to the manual is https://content.us.dynabook.com/content/support/manuals/userguides/su2844172/xxdf56_om_e.pdf . It does not have any codes to control other TVs.
A universal remote that was programmed six months after your Spectre TV was manufactured would probably be a better solution for you. I hope this helps.
SOURCE: can't find remote codes for comast remote
Codes for Sony seem to work for Sceptre. I have Comcast On Demand Remote (with the red ok/select button) - there is more than one kind of remote for comcast). I used code 11100 and it works great for my Sceptre HDTV. Hope this helps!
Testimonial: "I used the code suggested. It worked fine as soon as I put it in. Thanks. "
SOURCE: my sceptre television picture is upside down, can
If you select "source" on your remote then enter 7343 it will bring up a factory menu. Go down to 'Other setting' , the setting 'scaler output' should be set to "Normal". This setting flips the display.
SOURCE: I have a Sceptre LCD
upgrading the firmware is the only possible solution if a factory defaults reset has not fixed the software issue only other thing would to have a diagnostic run by a technician on it
Robb
SOURCE: Toshiba Color Television 36A43 Lost the
Place one remote on table, place other (new) remote facing old remote, then push the program button on new remote, remotes IR screens has to face each other to make this work. and if you've tried to program the new one before, you will have to clear the new ones memory first. Good luck.
SOURCE: dish network remote control code for sceptre television
Hi, my name is Cheri Torres and I am with DISH Network Internet Response Team. I came across your post and wanted to see if I could help. I will list here for you the best codes for addressing a DISH remote to a Sceptre TV. I will also list the instructions for addressing your remote to your TV. I hope you find this information useful and if you have any further questions or concerns please feel free to ask.
Remote codes for Sceptre - 500 and 677.
Instructions for addressing the remote to the TV
1. Press and hold down the TV button until all the mode button light up red.
2. Enter the 3 digit code for your TV in the remote keypad.
3. Press the pound(#) button once.
4. Test the functionality of your TV.
