Need rca univeral remote code for a toshiba tv
1. Manually turn on the component you want the remote
to control.
2. Press and hold the component key (TV, DVD•VCR, AUX, SAT•CBL) you wish to program. The LED INDICATOR turns on and remains on. If you release the component key at any time during the Direct Code Entry procedure, the LED INDICATOR blinks four times, and the process is exited.
3. While holding down the component key, enter the four-digit code. While you are pressing the numbers, the LED INDICATOR turns off.
4. After the fourth number is entered, the LED INDICATOR turns on. At this time, release the component key. If the LED INDICATOR turns off, you have entered a valid code and have followed the correct procedure for Direct Code Entry.
If the LED INDICATOR blinks four times when the component key is released, This means that a programming error has occurred. In that case, repeat the Direct Code Entry process from step 2.
RCA Toshiba 3 digit codes. 000,018,021,023,048,049,071,072,073,085,...
RCA Toshiba 4 digit codes.1000,1048,1072,1105, 1109, 1118,1160,1190,1241
Good Luck
