Model 4213x stapler. What does blinking red light indicate?
Posted by lpgplus on
1 Related Answer
johnedpatton
John Patton
SOURCE: What does it mean when a red light if flashing on
Time to change the batteries
Posted on Sep 23, 2011
Panasonic tv 42 inches plasma model no TH-42PX80EA one red blink light
One blink code indicates main board issue (ALSO can be a BAD panel)
Here is YouTube Link:
https://www.youtube.com/watch?v=HUxD72qoays
I’m happy to help further over the phone at https://www.6ya.com/expert/mike_316638c836088218
Mar 30, 2018 | Panasonic Televison & Video
Noticed when laundry room is dark you can see a blinking red light under the area of the lint trap on Frigidaire stackable washer/dryer model FFLE1011MW1. Just curious to what that may be.
I did some research on this. It appears the blinking red light is to indicate there might be a problem. The "blinking" is actually an error code. A certain number of "blinks" is indicative of certain types of errors. This is similar to a cars "check engine light". A car is scanned to get the code, which can help lead to the problem. I found a common source for dryer codes according to the blinking red light here:
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134859700e.pdf
I hope this helps :-)
Jan 28, 2016 | Frigidaire Washing Machines
Red blinking lights
What is the brand name and model number to your TV. Standby light blinking are fault indications. Check this for more details about the blinking codes. You haven't provided sufficient details here, so I can indicate the source to know more only.
Jan 05, 2013 | Televison & Video
Panasonic viera no picture, power indicator light flashing red
l would suggest if knew the model number which is not indicated an answer ===red blinking is usually in a sequence like ten blinks, pause and indicates an error code.
Apr 08, 2012 | Panasonic Televison & Video
MY TV DOES NOT TURN ON AND I HAVE A BLINKING RED LIGHT MODEL IS KP51HW40
the blinking red light is an error code. How many times is it blinking and I will let you know what the error is indicating?
Aug 22, 2011 | Sony KP-51HW40 51" Rear Projection...
Hi, Our Sony Bravia TV model number KDF E50A11E is not working. There is a red blinking light flashes three times and then goes green and then red blinking again after about 3 seconds. Is this a bulb...
On that particular model I believe there is both a lamp indicator light and then the power indicator light. If it is lamp related the lamp indicator light (LED that looks like a sun in a cup...) would be on.
If the power indicator light is flashing red to green, that is a self diagnostic code, and you will have to contact an authorized Sony repair fascility for them to translate the problem. The error codes are not listed in the user manual, since most are not user serviceable.
Mar 01, 2011 | Sony (XL-2400) Projector Lamp for...
Memorex Phone model MPH692-red light continues to blink
The light may be a "new call indication" or "message waiting" indication if you have voicemail service from the phone company. If you clear the caller id log or clear the voice message the light should go out. BUT, it will keep coming back on when a new call arrives! I have a similar phone and I just put a piece of tape that matches the color of the phone over the light.
Apr 21, 2010 | Lands Phones
Light blinks like it wants to come on then 2 red lights blinks under the blue lighttemp and lamp are red lights tv want come on
Without the model number, I can't provide any details, but you should be able to look this up in the owner's manual. Usually blinking lights like this indicate a bad lamp, bad fan or something similar. The owner's manual will have a chart that shows what the indicators mean. If you can not find the manual, please post the model number and I'll look for one.
Thanks,
Dan
Jul 17, 2009 | Hitachi Televison & Video
RCA Model 32V434T Ch. #ATC010A will no come on. You can hear a click when it is turned and the red indicater light blinks. If you push the menu button after awhile the red light will stay on and not blink....
Model 32V434T Ch. #ATC010A will no come on. You can hear a click when it is turned and the red indicater light blinks. Eventually the red indicator light stays red. Tried unpluging set. Is it the EPROM ?
Jan 19, 2008 | Televison & Video
13 people viewed this question
Marvin
Marvin
