Question about LG Televison & Video
When I turn the TV on it the picture will show for a second then go black screen it will continue picture no picture.
SOURCE: My tv blinks from regular picture to a black screen continuously.
your tv is on the blink.
remove the back panel of set
on the crt pcb board you will find a wite or black pot.
turn it up or down while set is on this is the [email protected] voltage ajustment.
you might get 3 monts to a year of extra life from your pictor tube by doing this.
regards,
daniel.
Posted on Jan 13, 2009
SOURCE: lg lcd tv picture goes in and out with "boxes" on the screen
This sounds like the power supply that feeds your back-light is going out. This repair should be done by a qualified technician
Posted on Mar 13, 2009
SOURCE: TV goes black
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
SOURCE: LG TV - TV Guide Function Stuck
I have the same issue on an LG TV. The TV Guide is completely black with a small picture in the corner. It's as if the software is no longer working.
Posted on Jul 31, 2009
SOURCE: loud pop...LG Model 50PQ30-UA Standby light blinks on/off
this **** dont mother ******* work **** ALL YALL HOES how u like that
Posted on Sep 20, 2010
Dec 06, 2017 | LG Televison & Video
Oct 26, 2017 | LG Televison & Video
Aug 11, 2017 | LG Televison & Video
Feb 22, 2017 | LG Televison & Video
Nov 29, 2016 | LG 60PZ550 3D Plasma TV
Feb 22, 2016 | LG 42LS3400 42" Class FuHD 1080p LED LCD...
Nov 03, 2015 | LG Televison & Video
Jul 20, 2009 | LG 32LC7DC 32 in. LCD HDTV
Mar 13, 2009 | LG RZ32LZ50 32 in. LCD Television
16 people viewed this question
