One of the main common reasons why a washing machine will continue to fill with water when it is turned off is due to a failed water inlet valve and the water inlet value needs to be replaced. This valve controls the flow of water into your washing machine that's required for both the rinse and wash cycles.
Posted on Jan 22, 2021
SOURCE: water flowing out of the machine
i woulds assume that the air line responsible for monitoring water level has disconnected form the side of tub. with a screwdriver you can pry the main top up. approx, 3-4 inches in from either side of the front panel( where teh top meets the front panel, youll find a spring type clip that with some pressure will release0 and allow you to flip the ,main top backwards. afet that yo can look down the left rrear side of drum and see the 1/4 plastic tubing( i would assume dangling there) reconnect to the side of drum adn all should be good.
Posted on Mar 01, 2009
Apr 18, 2015 | Maytag Neptune MAH5500B Front Load Washer
Aug 23, 2012 | Whirlpool Washing Machines
Dec 27, 2010 | Kenmore 22622 Top Load Washer
Nov 16, 2010 | Maytag Legacy MAV208DAWW Top Load Washer
Jun 07, 2009 | GE WDSR2080D Top Load Washer
Apr 14, 2009 | Washing Machines
Dec 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
Dec 05, 2007 | GE Profile WPSR3120WWW
Jul 07, 2007 | Maytag PAV2300 Top Load Washer
15 people viewed this question
