Question about Frigidaire Washing Machines
SOURCE: Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Posted on Jun 29, 2006
It sounds like the bearings are going bad. Try spinning the drum with your hand while it is empty. It should spin nice and smooth. If the rotation feels a little rough and noisy, you might have a problem. You can double check by taking the drive belt off and try shaking the pulley. If there is "play" when shaking the pulley, the bearings are most likely toast. The inner stainless drum rides on two bearings which sit in the rear of the outer plastic drum. The whole plastic drum and bearings come as one piece and go for $150. It would cost about the price of a new maching to have someone come out and repair it for you. It sounds like kenmore has had a bearing problem which is pretty rediculous considering how much these things cost. Sears said, "those tend to go in a few years", which is criminal especially since the warrenty is usually conveniently exopired by the time this problem happens. If you are handy, have a spare day, and can remember how to put a washing machine back together, go for it. I did it and it was not a fun time. There is a lot of sharp metal edges in the machine so wear gloves. good luck
Posted on Nov 14, 2006
SOURCE: WASHER SOUNDS LIKE AN AIRPLANE TAKING OFF DURING SPINE CYCLE
Most likely a failed "spinner" assy. The roaring that you hear is the bearing telling you it's had enough and has gone on strike.
MAJOR job! If it's over 5 years old, I recommend calling a professional and get quotes. Then decide what you want to do.
If it's less than 5 years old, it should be under warranty. Contact Sears. Tell them you have a failed spinner and tub bearing assy. and have them do the repair.
*Just a quick note. You should use only HE detergent in these machines.
Tracy
Posted on Oct 28, 2008
SOURCE: spin cycle on washer sounds like an airplane engine starting up
Hi Neptune owners,
Don't forget to change your door latch wax motor. Here is a song that will help you www.neptunehelpsong.com.
Posted on Feb 08, 2009
SOURCE: my washer sounds like an airplane taking off when
its probebly the main bearing. disconect the power and remove the back. then slide the belt off the big pulley. if you see alot of brown splatter you know its the bearing.if not with the belt removed go to the front and open the door spin the drum fast, if it makes the same noise its the rear bearing.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Posted on Jan 15, 2010
Jun 30, 2014 | Frigidaire Affinity ATF7000E Front Load...
Dec 27, 2012 | Frigidaire Affinity ATF7000E Front Load...
Nov 04, 2010 | Maytag Atlantis MAV6000 Top Load Washer
May 20, 2010 | Fisher and Paykel GWL11 Top Load Washer
Feb 14, 2010 | Maytag MAH2400A Front Load Washer
Jun 12, 2009 | Frigidaire Affinity ATF7000E Front Load...
Feb 03, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Jun 27, 2008 | Washing Machines
May 05, 2008 | Frigidaire GLTF1670A Front Load Washer
Jun 29, 2006 | Kenmore 43042 Front Load Washer
14 people viewed this question
