Question about The Video Game Consoles & Games
NXP3-492 controller. How can I get USB cable to connect to PS3?
Posted by jose montalvo on
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: PS3 controller Problem
I just fixed mine. The controller itself needs to be reset. There is a reset button on the back of the controller, above the top right hand corner of the square with all on the information and barcode. Press it with a sharp tipped object while still connected to the PS3 via USB cable. Then press the PS button and you should be back on wirelessly.
Posted on Jul 09, 2008
Anonymous
  • 15 Answers
SOURCE: JAPANESE PS3 CONTROLLER WONT CONNECT
If You Live In Canada Or America The Controller Will Likely Not Work Because It Was Designed For A Japanese Ps3 But You Should Attach To Usb Cable To The Controller And To Your Ps3 And Leave It For An Hour And It Should Work Then If Not Then It Is Broken Or Your Usb Cable Is
Posted on Jun 27, 2009
Anonymous
  • 31 Answers
SOURCE: my wireless controller wont connect to my ps3
maby the controler needs charging
Posted on Jun 30, 2009
Anonymous
  • 12 Answers
SOURCE: PS3 does not detect controller even with a USB cable
hold down the ps button. and then connect a usb cable .
Posted on Sep 04, 2009
Anonymous
SOURCE: My controllers will not connect with my ps3 with
there is a small reset button at back of control
Posted on Oct 09, 2009
Hi eveyone i have a ps3 and a Logitech wireless controller but won't connect to the ps3 please help
If there is a USB cable /charging port plug into PS3. If this doesn't have a USB cable /charging cable using your other ps3 controller turn ps3 on, scroll over to the settings, manage blue tooth accessories, turn controller on in discovery mode , and follow steps on screen to pair your PS3 and controller
Aug 11, 2014 | Video Game Consoles & Games
Gioteck vx1 wireless controller will not pair up to my ps3
This works: Turn ps3 on. Plug the controller into the usb cable and into ps3. Then plug the dongle into other usb port. After a short time the dongle will flash quickly (this means it's in pairing mode - when the dongle flashes slowly it's too late). Press the PS/Home button as soon as you see the dongle fast flashing. All the LED's on the controller will begin to flash and after a short time one (or two) will remain solid. Immediately disconnect the charging usb lead from the controller and again the LED's will flash, push the PS/Home button again and after a short time one or two will remain solid. The controller should now be working. If the controller fails to respond repeat this process but make sure that you disconnect the dongle and reinsert (so you can see the fast flashing lights and try again).
Jan 04, 2012 | Video Game Consoles & Games
My controler for my ps3 is not working
Unless the controller hardware has failed, I'd surmise it has somehow lost its wireless pairing (setup of identification and link with the base unit). Connect the controller to the base unit with a USB cable and turn the base unit on. The pairing will be done automatically. Next, give the controller an ID number between 1 and 7.
Once that is done, you should be able to disconnect the USB cable and use the controller normally. (You do not have to turn off power to disconnect a USB cable.) If the Playstation base does not recognize the controller when it is plugged in with the USB cable, the controller has a bad part inside.
If the controller works normally when plugged in, but not in wireless mode, there is a problem with the wireless operation. This could be either failure in the controller or base unit, or interference from some other device nearby. For example, a furnace igniter emits RF energy over a wide range of frequencies; if the controller works only when the furnace igniter is not running (you can hear the sparks on an AM radio while it runs), then the furnace ignition circuit is the real culprit, and you should check its ground wiring.
Dec 09, 2011 | Sony Playstation 3 (PS3) Console
My mad catz controller will not configure to my ps3.How can i do it wireless?
sir good day there are two way on how to configure your wireless controller to your ps3 console.... the automatic pairing and a manual pairing
first way an automatic pairing
1.turn on your ps3..
2.Connect the smaller end of the included USB cable to the PS3 controller.
3.Connect the opposite end into either USB port on the front of the PS3.
The pair light on the PS3 will flash. When it stabilizes, you can disconnect the USB cable
and use the controller wirelessly.
second way a manual pairing
1.. turn your ps3..
3.Connect the opposite end into either USB port on the front of the PS3. Press the "PS" button on the center of the PS3 controller. The pair light on the controller will flash. When it stabilizes, you can disconnect the USB cable and use the controller wirelessly.
you can try that 2 way on how to configure your controller to your ps3 console if this help you please rate me thank you sir..
Jun 12, 2011 | Mad Catz Call of Duty Black Ops...
My ps3 controller wont come on it just flashes 4 times and switches off maybe its because i opend my ps3 system but i put everything back to normal some 1 plz help me!
This usually means that your ps3 controller is no longer paired to your ps3, to re-pair them attach the controller to the ps3 using the usb cable, then press the ps button again when the ps3 is on.
Mar 21, 2011 | Sony Playstation 3 (PS3) Console
How do i pair my ps3 controller to a new console.
To pair your controller back with your PS3, just connect it with a USB cable and press the PS button. Just like you did when you first got your PS3.
Sep 22, 2010 | Computers & Internet
I have a battery operated controller and can not pair it to ps3 please help the controller came with the ps3 as well as standard one thank you
To sync a controller you need to plug it into the usb cable that comes with the playstation itself. If you've lost the cable you will need to buy a new one unless you can find a similar cable.
This allows the controller to be used on multiple playstations, to synchronise a controller to a certain playstation, the usb cable is vital!
Hope this helps.
Aug 14, 2010 | Sony Playstation 3 (PS3) Console
PS3 wireless battery operated controller, doesn't have the option of USB cable, will not pair with PS3 console?
  1. connect your controller to the PS3 with the controller charger cable (not original, nor pairing, only charging), then turn on the ps3 followed by controller (had a using controller on and assigned controller one , automatically)
  2. i used a pencil, and while all lights blinking, poked the small hole near front, L2, and on back
  3. it should now flash 2 time, and only 2,
Jan 18, 2010 | Sony Wireless Controller for PS3
Video Game Consoles & Games Logo
13 people viewed this question
Top The Video Game Consoles & Games Experts
Marvin
Marvin
Paul Carew
Lawrence Oravetz
Are you a The Video Game Console and Game Expert? Answer questions, earn points and help others
