Question about Yamaha CDX-396 CD Player
Yamaha cdx-396 cd player not spinning or reading disc.
So the first problem i had was tray not opening. After a bit of tinkering i got it open and it soon became apparent that the problem was laser module not clamping down, and on this player that is done mechanically and i just synced the gears and that problem is fixed, now the laser clamps down when ejecting and up for playing. Now to my actual problem (i included previus part because i probably screwed something up there)... When putting in a disc, i get the same result as when i try to play something without actually inserting any disc, track 0 at 0:00. Now i think it is trying to tell me the infamous "no disk" error, just the display doesn't have such a function. I also can very much see that the disc is very much not spinning, and clicking sounds can be heard. I think that is the laser trying to focus. So i did all i knew for and cleaned the diode and adjusted the voltage, but to no avail.
Posted by Filip Bakic on
Tom Chichester
    Top Expert:
  • Yamaha Master
  • 61,334 Answers
The player has failed
Posted on Jan 24, 2021
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: my CD changer's disk tray keeps opening up, refuses to play discs
You have a problem with the try control circuit. It could be the switch is leaking across itself. Could be a problem with the tray motor control IC, or the Microprocessor is not reseting the open tray line correctly, or theres a cam assembly inside the unit that tells the microprocessor where everything is by means of small micro/leaf type switches thats out of alighnment or broken. If its seven years old, you got more then it was designed for and I would'nt invest a dime or the time into the repair of this unit. Time to take a trip to the electronics store. Good luck
Posted on Jul 21, 2006
Anonymous
SOURCE: Display says "LOCKED", won't eject disk, all other functions work. Need unlock procedure.
Had the same problem. Found an answer digging around and it worked: Press the STOP button and the OPEN button at the same time. Hold for about 10 seconds and it UNLOCKS.
I even went back to Bestbuy and they had no clue. But it worked!
Good luck.
Posted on Jan 20, 2008
Anonymous
SOURCE: this disc cannot be played
I am tired of these tediuos firmware updates that are for the most part USELESS. I have done everyone till their latest 1.8v. I still can only watch 1/3 of new monvies which really arent all new now. I paid $1000 some for this flagship unit. In my book it has sunk. Samsung will not even address my problem except wait for a firmware comming soon. I WANT A REPLACEMENT OF A SIMILAR NEWER MODEL OR REFUND. I have spent well over 20,000 on samsung home theatre products and I will boycott them forever. When I pay for something I want my moneys worth.
JEFF
Posted on Nov 23, 2008
Anonymous
  • 51 Answers
SOURCE: games wont play. Problems with Disk player
If you don't have the tools to open your 360 go to best buy or an office supply store and get a can of compressed air and blow the dust out of the dvd drive. If that doesn't work then the lens needs to be cleaned with a q-tip and alcohol. This has worked for me on numerous occasions.
Posted on Jun 01, 2009
Timm
uplug then replug then press eject
Posted on Oct 05, 2011
Detrola cd player spins too fast
Did you undo any leads when you changed the belt, are they in the correct position, it's spinning fast because it can't focus.
Aug 29, 2014 | Televison & Video
I have a CDX-602 CD Player. I was on a gig the other night I placed a cd in the tray. I pressed the button to close the tray and a cord was wedged so that the tray would not close. Naturally the tray...
The gears have probably come out of sync, meaning the tray is riding on the limit switch. You need to remove the deck, dismantle and re-sync the drawer mech. Check the limit switch isnt bent, it's quite flimsy
Aug 21, 2010 | Philips Gemini CDX-602 Dual CD Player with...
Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Mar 30, 2010 | Philips CDR775 2-Disc CD Recorder
The disc tray of my Yamaha cdc-745 CD player does open properly.
It's the belt inside the machine - open tray and look in front left side and you will see it. Easy to change out with new one.
Dec 13, 2009 | Yamaha CDC-745 5-Disc CD Changer
Memorex dvd player 2040..disc won't stop spinning!
This is due to faulty DVD lens/head. Try cleaning it with DVD/CD hed cleaning CDs.If still the problem persists, contact near by service center for replacing the faulty Lens.
Mar 13, 2009 | Televison & Video
Open/close tray disc stuck bose Lifestyle 48
Problem:
I also have a bose Lifestyle 48, and the same problem has happen to me where the DVD player would not open,
Solution:
Unplug the unit, Wait a few seconds, after plugging the power back in, immediately hit eject so that the player does not have time to spin up and try to read the disc again
Feb 17, 2009 | Bose Lifestyle 48 System
Cd Tray
Hi Fred..
I've done about 100 CD transports so far.
Try changing any belts in the unit. On some CD players ,if the open/close belt is bad, it wont allow the CD to be read either.
Also,VERY lightly cleaning the laser lens and dusting the unit out helps too.
Dec 28, 2008 | Yamaha CDC-845 5-Disc CD Changer
5-Disc CD player
your tray is out of track, have to place it back. not that easy but you can try. dont force it of you can damage the tray or gears
Nov 21, 2007 | Yamaha CDC-765 5-Disc CD Changer
CD tray repeatedly opens and closes
is this a yamaha 5 disc changer, table. not the cartridge type...
Aug 02, 2007 | Yamaha CDC-502 5-Disc CD Changer
Yamaha CDX-396 CD Player Logo
18 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Will
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
