Dryers Logo
cindi ellis Posted on Jan 21, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My minkaAire fan used to work on high speed and now only operates on low. Got a new universal remote w/ sensor - same problem .
David Spradling
Level 3:
Top Expert:
  • Dryers Master 13,522 Answers
  • Posted on Jan 24, 2021
David Spradling
Dryers Master
Level 3:
Top Expert:
Answers
13522
Questions
0
Helped
929174
Points
28390
Bad high speed relay
Synchronize MinkaAire Remote Control Fans
use two remotes. one fan is in the reverse direction and other forward and it is easier to use 2 remotes.
Jun 02, 2018 • Dryers
Need a wiring diagram of the 2 wires from the temp sending unit that controls the temp gauge and cooling fans on a 99 grand am gt. Need to see where they go They disappear behind the engine
The PCM regulates voltage to the coolant fan relays, which operate the fans. Refer to Engine Controls.
Engine Cooling Fan Description - Electric
The electric cooling fans are used to lower the temperature of the engine coolant flowing through the radiator. They are also used to cool the refrigerant (R-134a) flowing through the A/C condenser.
Operation
The electric cooling fan operates when the engine cooling temperature exceeds a certain value. The cooling fan on this engine is controlled by the PCM. The cooling fan has one speed. The PCM turns the cooling fan ON by grounding the coil of the cooling fan relay when certain conditions are met. When the A/C is requested, the cooling fan will also be turned ON.
Power for the cooling fan motors are supplied through Cool Fan #1 and Cool Fan #2 relays. The cooling fan relays are energized when current flows from the fuses in the Cell 23: Cooling Fan Controls , and through the relay coils to ground through the PCM. The Low Speed fans control circuit is grounded for low speed fans operation. During low speed fans operation, both fans run at a slow speed. The High Speed fans control circuit is grounded for high speed operation. During high speed fans operation, both fans run at high speed.
Important: When certain Diagnostic Trouble Codes (DTCs) are present, the PCM may command the cooling fans to run all the time. It is important to perform Powertrain On Board Diagnostic (OBD) System Check prior to diagnosing the engine cooling fans.
If a problem that involves the low speed cooling fan relay control circuit exists, DTC P0480 should set. If the problem affects the high speed cooling fan relay control circuit, DTC P0481 should set. A problem with the ECT sensor should set DTC P0117, P0118, P1114, or P1115. Any of these DTCs will affect cooling fan operation and should be diagnosed before using the Cooling Fan Diagnosis tables. The Cooling Fan Diagnosis tables should be used to diagnose the PCM controlled cooling fans only, if a DTC has not set.
The engine coolant temperature (ECT) sensor (3) is a thermistor, a resistor which changes value based on temperature, mounted in the engine coolant stream. Low coolant temperature produces a high resistance (100,000 ohms at -40°C) (-40°F), while high temperature causes low resistance (70 ohms at 130°C) (266°F).
The PCM supplies a 5 volt signal to the ECT sensor through a resistor in the PCM and monitors the terminal voltage. Since this forms a series circuit to ground through the ECT sensor, high sensor resistance (low temperature) will result in high PCM terminal voltage. When the resistance of the ECT sensor is low (high temperature), the terminal voltage will be drawn lower. This terminal voltage indicates engine coolant temperature to the PCM.
A hard fault in the ECT sensor circuit should set either a DTC P0117 or P0118. Remember, these DTCs indicate a malfunction in the engine coolant temperature circuit, so proper use of the DTC table may lead to either repairing a wiring problem or replacing the sensor, to properly repair a problem.
The engine coolant sensor is an input to the PCM , Two wire's both go to the PCM .An the PCM turns on the cooling fans !
DTC P0480 Cooling Fan Relay 1 Control Circuit
DTC P0481Cooling Fan Relay 2 Control Circuit
The Body Control Module (BCM) request the cooling fans. The BCM sends a Class 2 message to the PCM in order to enable the fans based on various inputs. Thebattery voltage travels to all three cooling fan relay coils. The PCM enables cooling fan relay #1 by providing the ground path. The PCM enables cooling fan relays #2 and mode control together by providing a ground path. The left and right cooling fans are connected in series. This will enable both fans on low speed when the fan #1 relay is energized. When all three fan relays are energized, both fans will operate at high speed. The high speed is possible because the fan relays are wired in a parallel circuit. When the PCM detects that certain DTCs are set, the PCM will enable the cooling fans.
The PCM will enable the engine cooling fans when certain Diagnostic Trouble Codes are set.
Important: A short to ground will cause an open fuse(s). Before performing this diagnostic procedure, inspect the fuse(s) for an open.
Did you perform the Instrument Cluster System Check?
Go to Step 2
Go to Instrument Cluster System Check
Turn the ignition switch to the ON position.
With the scan tool select Instrument Panel Cluster, Special Functions, Instrument Panel Cluster (IPC) gauges.
Perform the Coolant Gauge Sweep Test.
Does the coolant temperature gauge complete a full sweep when commanded?
Go to Powertrain On Board Diagnostic (OBD) System Check in Engine Controls
Go to Step 3
Replace the instrument cluster. Refer to Instrument Cluster Replacement .
Did you complete the repair?
Your best bet would be to take your vehicle to a qualified repair shop that knows how the system works . An has the tools to diagnose the problem .
2answers
How do I program a MinkaAire R211 remote?
How do I program a MinkaAire R211 remote? - Fixya
www.fixya.com/support/t26033435-program_minkaaire_r211_remote
2 hours ago - I have set the wall mount, hand held R211 remote and the fan receiver to the same frequency. 1 & 2 ON and 3 & 4 OFF. But the remote still wont ...
[PDF]Universal Hand Held Remote System - Minka Group
minkagroup.com/sites/default/files/product.../RC212-English.pdf
NOTE: The RC212 Universal Hand Held Remote Control System is equipped with a learning frequency function which has 256 code combinations to prevent ...Missing: r211
Minka Aire Remote Control RCS212 and Wall ... - YouTube
? 0:56
https://www.youtube.com/watch?v=359xzOXynxI
Jun 14, 2013 - Uploaded by Del Mar Fans & Lighting
Del Mar Fans & Lighting's Minka Aire specialist provides tips for using these innovative ceiling fan controls ...
Jan 01, 2016 • Dryers
Martec quadrant DLQ134B -Why - I have two fans which only just operate on low, no other response to medium or high. Have replaced batteries to controllers but makes no difference to the operating of same
Considering you have the same problem with both the fans and using law of probability I would say your fans are ok. My guess is that you are operating the fans in winter mode (reverse). In this mode the fan only works on low speed for obvious reasons. Switch the fan to Forward mode (using remote control) and check if the 3 speeds are working.
http://www.martecaustralia.com.au/products/ceiling-fans/martec-ceiling-fans/quadrant-series/quadrant.html
Apr 24, 2014 • Dryers
3helpful
2answers
My fan reversed, but my controller does not have a reverse button
There is a switch on the housing of the fan. It is under the blades and above the lites if you have lights. Also same area as the chains. That is the reverse switch you might have hit it when cleaning the fan. just flip the switch iy goes left to right or reverse.
Good Luck and please rate
Casablanca fan speed problem
If this fan has a pullchain that also controls the fan speed, and you have a remote, the pullchain has to be set for the highest speed. If it is set at medium or low, it will mess with the remote operation. Note: usually high speed is the first pull after the "off" position.
13helpful
3answers
Van chevrolet venture 2000
Fifteen minutes! you have bigger problems than only the fans the fans are controlled by a thermo switch that is heated by the coolant, If you have no coolant the sensor cannot activate But fifteen minutes seems like you may have a headgasket problem and steam cannot heat the coolant sensor.OperationNotesThe electric cooling fan operates when the engine cooling temperature exceeds a certain value. The cooling fan on this engine is controlled by the Powertrain Control Module (PCM) . The PCM turns the cooling fan ON by grounding the coil of the cooling fan relays when certain conditions are met. When the A/C is requested, the cooling fan will also be turned ON.
Power for the cooling fan motors are supplied through Maxifuses(R). The cooling fan relays are energized when current flows from the fuses in the Underhood Accessory Wiring Junction Block, and through the relay coils to ground through the PCM. The Coolant Fan 1 Relay Control Circuit is grounded for low speed fans operation. During low speed fans operation, both fans run at a slow speed. The Coolant Fan 1 Relay Control Circuit is grounded for high speed operation. During high speed fans operation, both fans run at high speed.
IMPORTANT: When certain Diagnostic Trouble Codes (DTCs) are present, the PCM may command the cooling fans to run all the time. Perform the A Powertrain On Board Diagnostic (OBD) System Check prior to diagnosing the engine cooling fans.
For more information regarding the Charging System, refer to Charging System Description , and Charging System Circuit Description in Starting and Charging.
If a problem that involves the low speed cooling fan relay control circuit exists, DTC P0480 Cooling Fan Relay 1 Control Circuit should set. If the problem affects the high speed cooling fan relay control circuit, DTC P0481 Cooling Fan Relay 2 Control Circuit should set. A problem with the ECT sensor should set DTC P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage, DTC P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage, DTC P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage, DTC P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage. Any of these DTCs will affect cooling fan operation and should be diagnosed before using the Electric Cooling Fan Diagnosis.
For more information regarding the Cooling System refer to Engine Cooling Fan Description - Electric, and Cooling System Description in Cooling System.
Here is the electrical schematic and how it all is suppose to work,
If you need any further help please contact me Thank you,Randy If you find this information helpful please give me a good rating
www.aceautomotive1.com
Top Dryers Experts
john h
