Jetair 36,000 BTU cassette A/C. What does E4 code indicate?
Posted by Norman on
2 Related Answers
Rich Landrum
  • 4736 Answers
SOURCE: Chigo 12k BTU A/C E4
The "E4" error code indicates a host of possible problems. More than can be listed here. So, I have included a link to your model's Service Manual that you can download & print if you so desire. Pay particular attention to pages 32, 33 & part of 34
www.chigo.us/support/downloads.html?download=3%3Aservice-manual
I hope this helps you and thanks for choosing FixYa.
Posted on Aug 23, 2011
Grubhead
Grubhead
  • 5700 Answers
SOURCE: Mitsubishi VCR Model HS-821V Ejects Video Cassette & gives an error code E4
Sometimes things like that are caused by the mode switch which will either need to be cleaned or replaced. It's worth looking inside for damage inside the unit. Pay close attention to plastic parts.
Posted on Nov 28, 2012
Jetair air conditioner displays error code E5 what might be the problem?
it usually suggest coil sensor problem, this can be caused by either:
1. dirty filter (restricted flow)
2. damaged sensor (or just repositioned during cleaning!)
3. insufficient coolant - check for leaks! especially around valves
4. defect on the sensor contact
5. compressor motor (due to coolant shortage...)
6. damages blades on the fan
hope this little info will help you with diagnostic of your problem, do not forget to vote...
Jan 27, 2015 | Heating & Cooling
E4 error code beautyrest electric blanket
beauty rest electric blanket error code - akaQA
www.akaqa.com > Uncategorized
beauty rest electric blanket error code. What does error code E4 mean? Answer this. 0 Views: 2487 Answers: 1 Posted: 3 years ago. Comment this question.
E4 error code beautyrest electric blanket - Fixya
www.fixya.com/support/t22178587-e4_error_code_beautyrest_electric
Dec 13, 2013 - E4 error code beautyrest electric blanket One side works the other returns an "E4" error code - Simmons Beautyrest Microfleece question.
Dec 13, 2013 | Simmons Beautyrest Microfleece Electric...
Nov 26, 2012 | Televison & Video
I have a contractor that wants to install a 36000btu outdoor unit(model # mh080fxca4a) and two indoor 18000btu indoor units(model #mh052fnca). What would be the output of the outdoor unit? The contractor...
Yes it rated for a maximum out put of 36,000 btu (3 ton) with the right indoor fan coil units which based on the model numbers should give the 36,000 btu's combined when both fan coil units are on, otherwise 18,000 btu's (1.5 ton)per fan coil.
Aug 23, 2011 | Samsung Heating & Cooling
We got this panasonic fp-7718 for free and have tried to get it to copie but the e4 code keeps and i have no idea how to reset this code or any of the other codes.
There will be more to it than just E4..........it will say E4-01, E4-10,11, OR 12.
If its e4-01...that means the machine is not warming up and may have a problem with the Fuser unit.
If its E4-10,11 or 12 it relates to a problem with a Fan motor.
Thats the best I can do given the information you have provided.
Feb 26, 2011 | Office Equipment & Supplies
JA4 jetair electic, light won't work, have replaced with 2 new blubs still does not work ,used glove to handle blubs
fuse isn't any good ussually tied to the ac outlet, check the ac outlet on the range for power it probibly isn't working either,this will confirm it for you.
Jun 21, 2010 | Ovens
Error 1 comes up on screen when cd played panasonic rx77 cd and cassette player.has active screen.
Don't know if this will help, but with my panasonic CQ-C8300N there are 4 error messages, all to do with CDs.
They are as follows:
CD E1 - Disc is dirty, or upside down.
CD E2 - Disc has scratches.
CD E3 - No operation by some cause! - see your dealer.
CD E4 - The file is not readable.
From my panasonic manual.
Jul 28, 2009 | Panasonic Car Audio & Video
Panasonic Split System Air Conditioning.
we have a old national air con cassette model cu-5chv11p , works for three days , then controller comes on e4 error ,and then switches off , and will not reset .
Dec 28, 2007 | Heating & Cooling
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
