Question about Plumbing
SOURCE: water trickles out of sprayer head on pull out faucet.
Hi crossroadsjm,
I'm Harvey the Master Plumber.
Your problem is: soaked in vinegar water but did nothing. took off spray head from hose and the water stream is very small in diameter. only 1 year old faucet. could cartidge be bad or clogged? water pressure in rest of house is fine.
It is very possible that some debrie has come up in the water and is partially clogging the faucit. For this you would have to turn the water off and disassemble the parts clearing all the small passages, a bit of wire or paper clip works. Perhaps for a pro? If you like you may choose to utilize our Repair Directory.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 15, 2008
SOURCE: Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
Problem solved.
Posted on Dec 05, 2008
SOURCE: New Pfister Avalon Install: Spray Hose Works, Faucet doesn't
sounds like your diverter is stuck or improperly installed ,try tapping at diverter location to free up diverter the other thing to try is remove the little device on the end of spout make sure its not clogged with debri
Posted on May 04, 2009
SOURCE: Sulfur smell from the Delta faucet
Your incoming water from the well is contamiated. A delta faucet will combine oxygen with the water and make the sulfer smell come out. It could also be iron bacteria causing the smell. Look in the back of your toilet tank and see if your have reddish or black stringy algae looking stuff growing in there. If you do, you have iron bacteria and it will smell.
Posted on Nov 20, 2009
SOURCE: We are trying to replace a Grohe kitchen pull out
The universal hose will not work on certain model faucets,best bet contact manufacturer and they may provide you a new hose at little or no cost if you tell them you will put a different brand faucet in.
Posted on Jun 12, 2011
Testimonial: "Thanks, that is something I didn't consider. After much wrangling, he did get it loose and re-threaded it. It seems OK for now. Thank you for replyi"
Jan 13, 2012 | Plumbing
Dec 14, 2017 | Blanco Classic Single Handle Faucet with...
Jan 13, 2011 | Microwave Ovens
Oct 06, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Dec 23, 2009 | Delta Faucet 470-DST Signature Diamond...
Nov 12, 2009 | Delta Faucet Delta 470-BL-DST Signature...
Oct 31, 2009 | Price Pfister 532-7PCC Marielle Pull-Out...
Mar 24, 2009 | 2001 Chevrolet Venture
Nov 27, 2008 | Plumbing
