Question about Yamaha Audio Players & Recorders
Why does A/B right channel have no sound in DSP modes?
Channel works in analog mode (AM/FM radio). All other channels work fine, indicating a problem with the DSP card. Can card be repaired or replace only?
Posted by Shawn on
5 Related Answers
Anonymous
SOURCE: channel not working
If the Logitech Pulse 475 is the same as the Labtech Pulse 475 then the left channel amplifier probably blew. The Labtec uses a 5 pin TDA2030A, which costs around $3. You will need to know how to solder to repair this. The back of the case comes off by removing the 8 screws around the back of the case and lifting it out by the power cord. Then, simply desolder the left channel amplifier marked IC201 (it's on the leftmost side of the board, next to the volume potentiometer) and solder the new amplifier in it's place.
Posted on Oct 30, 2006
Anonymous
SOURCE: Sony Explode 4 channel amp in protection mode
sometimes if the power cable and the ground cable are frayed and touch it will short out the amp temporarily check to make sure allof the wires aren't touching each other
Posted on Aug 14, 2007
Anonymous
SOURCE: Right surround channel not working in some modes
I had the same problem with the right channel.    It turned out to be a broken wire inside the receiver; it can be found connecting from the main PCB to the card for the 5.1 board.    After repairing the broken wire, it has worked fine.
The harness connects the 5.1 low level signals to the board which are then redistributed to the amplifier section.     It is a bundle of wires in gray casing and with red, black and white wires (with shielding).
Find the offending wire, repair or replace and it should be fixed.
Hope this helps
Posted on Oct 27, 2007
Anonymous
SOURCE: Right Channel Not Working
I have had the front, left and right channels go out over time. I have fixed all of them, and each time it has turned out to be a cold solder joint. While I love NAD and will continue to purchase there equipment, this generation is plagued with poor workmanship.
To fix the channel going out, I removed the top cover. Back cover and 2nd card from the left (looking at the receiver from the back side). This card handles all of the audio processing. I have found cold solder joints all over this board which has caused channels to suddenly go quite. I have never found a bad component. Also, I have cleaned the interconnect to be backplane (board that the audio processing board connects to) in the case of the center channel going quite.
If you have poor FM reception, the first board from the left (looking at the receiver from the back side) may have a cold solder joint on the coaxial connection for the FM antenna.
Posted on Jul 13, 2008
Spottymaldoo
SOURCE: yamaha dsp a1000 left channel cuts out sometimes in surround mode, sterio works fine
The easiest way is to buy the new part online and replace it - cost about $50US.
However, if you're up to it, this problem is fixable without the need to buy any parts. The selector switch has four sets of spring contacts which need to be bent slightly to increase the pressure on the pads against which they press, but it's a tedious job and not for the faint-hearted.
Here's what you need to do:
Open the case (6 screws) and also free up the front panel (9 screws).
You'll see that the switch consists of a PCB, an aluminium box and a motor. Remove the two screws holding it to the front bulkhead. take oyr the small "L" shaped circuit board that overlays it. A plastic pop-in holds the bottom of the switch PCB and the switch assembly can then be removed entirely.
Next you will need to remove the aluminium switch box from the PCB. Firstly de-solder all the connections which hold it in place. Now pull it clear.
Here is the MOST critical part of the job: inside the switch box you'll see four circular plastic wafers - these contain the contacts you need to fix and you'll need to bend the tangs which hold the shaft assembly onto the housing and then the tags which are holding the wafers in place. Your difficulty will be making sure that the wafers go back on the shaft with the rightr alignment and that the wafers go back in the same order.
Take some digital pictures while the wafers are still on the shaft with the orientation of the KNOB included - if you mess this up (I did) the job becomes horrible! Also, mark each wafer with a number 1-4 because there are three different kinds Once you are comfortable that you can replace the wafers in the proper rotary configration with respect to the shaft, remove them individually and pop out the gray plastic cores and bend the spring contacts upwards so that they will go back pressing more firmly against the pads. Now reassemble, and good luck!
Posted on Dec 29, 2008
Hello how doi adjust the left and right balance for the left and right channel level
The only 'balance' is to adjust the channels relative to each other with the test tones.
http://www.retrevo.com/support/Pioneer-VSX-24TX-Receivers-manual/id/386ag014/t/2/
Page 29.
The "Effect/Channel Select" button on the Remote (left of the Menu button), will let you change the level to any channels while listening to a program. Page 22
"EFFECT/CH SEL +/- buttons (See p.38)
EFFECT : Use these buttons to increase or decrease
the amount of effect applied in a DSP or Advanced
Theater mode. When the amount of effect is
increased in a DSP/Advanced Theater mode the
characteristics of that mode become stronger and
more noticeable. The scale ranges from 10-90 with 70
as the default setting. First turn on the DSP/
Advanced Theater you want (by pressing the DSP/
Advanced Theater button until you get the mode) and
then increase or decrease the amount of effect.
CH SEL : You may want to adjust the channels when
listening to some sound sources. Use this button to
select the channel you want to adjust.
+/- : Use these buttons to select the amount of effect
in a sound mode and to adjust the channel"
Jan 16, 2011 | Pioneer VSX-24TX Receiver
I have a uniden GMR1448 Two-Way Radio. Both handsets work but they cannot talk to one another. They used to work fine. They are tuned to the right channel and I did everything that I find obvious, like sub...
Check whether the channel and the sub code are same?If this is not same it will not work.
Put the sub code to off.Follow the below steps
1.Press chan tone/scan in channel select mode.The subcode indicator will flash. 2. Press the UP arrow  or DOWN arrow key to increase or decrease the code number displayed.You can also select oF (OFF) at this stage. 3. Press chan tone/scan to exit the Menu.
Thank You
Nov 16, 2010 | Uniden GMR1448-2CK Two Way Radio
My yamaha DSP AX1 amp does not work when audio is connected via optical or coaxial any suggestions how to correct this. no sound comes from any speaker except the subwoofer.
Are all the speakers turned off (set to None) in the speaker menu.(except the sub)?
2 channel direct analog stereo may still work, but any surround modes will use the speaker settings and the full DSP digital section.
Check also the input mode isn't incorrect - although if the sub is wired correctly and gives sound this can't be whats wrong.
Aug 26, 2010 | Yamaha DSP-AX1 10-Channel Amplifier
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
Jun 29, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
I have a MTX8000 Handie-Talkie FM Radio It is a 16 channel radio
You're on scan mode but have no channel in scan list. You might have to go to scan PROGRAM mode and select the channel you want to scan then press a side button to put that channel in the scan list then will scan.
radcom907
Mar 15, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
STG DR510 no sound on left front channel
Can I assume the calibration procedure also didn't work for the Front left channel? (It's not a "surround" if it's in the front). Switch the receiver to Stereo mode to eliminate any DSP actions. Tune an FM station to eliminate any external device or cable issues. What do you hear from the two Front speakers?
OK? Select a DSP surround mode. Check all modes. What happens?
If the channel goes dead using some or all DSP modes there's probably something wrong with the processor. If they all work...
Isolate the source that exhibits the problem.
It was a bad left channel cable somewhere, wasn't it?
Dec 24, 2008 | Sony STR-DG510 Receiver
I cannot get the functions on the remote to operate.ie pbass dsp/eq etc?
The P.BASS function is only available with 2 channel LPCM sources such as mp3,Divx,cd
and wma. Press P.BASS button and "POWER BASS ON" will be displayed on the screen.
The P.bass does not work with DSP/EQ or DOLBY PRO LOGIC ll modes.
If you press P.BASS in the DSP/EQ mode, the DSP/EQ mode is automatically shut off and the P. BASS function comes on.
The DSP/EQ function is only available in STEREO mode.
Press the PL ii mode button to show STEREO on the display.
This feature works with CDs, MP3-CDs, 2 channel DVD-Audio, DivX and Dolby Digital discs.
When playing a DVD disc encoded with two or more channels, multi-channel mode will be selected automatically and DSP/EQ function does not work.
Nov 04, 2008 | Samsung HT-Z310T Theater System
Fm tuning
For the best possible reception in FM mode, please ensure that the earphones are securely
plugged into the T.sonic.
In FM Menu
Scan for a Channel
Press the right (Next) or left (Previous) of Joypad once to step through selecting the
channel. Alternatively press and hold the right (Next) or left (Previous) of Joypad to
quickly auto-scan for the next channel.
Feb 17, 2008 | Transcend T.sonic 610 MP3 Player
18 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Will
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
