Question about Sewing Machines
Harris. How can I thread it? - Sewing Machines
Posted by karen redgrave on
My cxl will not stay theaded way the thead does not brake it comes untheaded.
When threading the machine, pull at least six inches of thread through the needle's eye. Pull up the bobbin thread (see video) and then gently hold both threads gently with your left fingers when taking the first couple of stitches in your fabric.
How and Why to Bring up the Bobbin Thread
Nov 28, 2015 | Sewing Machines
I need help on how to thread machine model 117-812 kenmore sewing machine
Thread, thread guide, thead guide, tension, take up lever, thread guide, thread guide, needle.
Aug 24, 2013 | Kenmore 15208 Mechanical Sewing Machine
Upper thead will not catch bobbin thead
try a new needle--make sure the needle is the correct one for the fabric
being sewed
try rethreading the machine top and bobbin
make sure to use every thread guide
try a different bobbin--make sure the bobbin is turned the correct way
in the bobbin case
if the suggestion don't help then the machine may need to be checked for a timing problem
Dec 20, 2012 | Sewing Machines
My machine is not picking up the bobbin thread
check the needle to see if it's damaged
make sure to have a 3-5 inch thread tail on the bobbin
then make sure the top thead has a 3-5 inch tail , then hold the top thead with your fingers( away from the needle) & with the other hand use the handwheel on the right hand side of the sewing machine & slowly manually let down the needle into the bobbin area & see if the bobbin thread will come up that way
Sep 26, 2010 | Euro-Pro Shark 60 - 384
SEWING MACHINE WILL NOT STITCH ON TOP OR BOTTOM. EVERYTHING SEEMS TO BE THREADED CORRECTLY AND NEEDLE HAS BEEN REPLACED.
Always thread a sewing machine with the presser foot up - this will make sure the tension feature has control of the top thead.
Make sure the needle is properly placed - usually with the flat side toward the back of the machine.
Feb 22, 2010 | Kenmore 15218 Mechanical Sewing Machine
Thead keeps pulling out of needle
There are a couple of things to check, first of all check that your needle is installed correctly. Thread breaking will happen if the needle is a little off or installed backwards, or even if it may be the teenest bit bent. Best bet is to put in a new needle and make sure the groved side of the needle is towards the back of the machine.
A misaligned needle can also throw the tension out, so once you are sure about the needle you will have to adjust the tension following your machines instructions.
Dec 15, 2009 | Brother LS-2125 Mechanical Sewing Machine
JAM
You need to re-thead upper thread. Yur not in tension. Raise pressure foot & re-thread.
Aug 22, 2009 | Singer 8280 Mechanical Sewing Machine
Singer 9015 sewing machine - bobbin loading
bobbin goes under the door of the needal, the thead come out from the right to the left, thead goes in the first edge and up and out of the left, you need the needal to be treaded, turn the round right know till the needal goes in and out , pull the tread up and out together.
Nov 26, 2007 | Sewing Machines
Sewing Machines Logo
12 people viewed this question
Top Sewing Machines Experts
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
