Question about Danby DDR7009REE Dehumidifier
How can I replace control board? - Danby DDR7009REE Dehumidifier
Posted by Walter Henningsen on
Danby Dehumidifier DDR7009REE leaking water, bucket not full
The unit may need cleaning. You can contact Danby customer service (1-800-263-2629) to get in contact with a technician.
There may be something clogging the passage to the bucket and the water is finding the path of least resistance.
As well, it is important to remember to clean the filter once a month.
May 14, 2012 | Danby DDR5009EE Dehumidifier
My DDR7009REE HAS WORKED GREAT FOR A MONTH. BUT NOW IT LEAKES ON THE BASEMENT FLOOR. I SHUT IT OFF FOR 2 DAYS THINKING IT MAY HAVE FROZE UP. TURNED IT BACK ON AND IT LEAKS ON THE BASEMENT FLOOR INTEAD OF...
dehums remove humidity from air inside unit the evaporator sits in drain pan , drain pan has some sort of line or tube witch leeds to the internal collection or bucket thats what you slide out and empty when its full , ther is some sort of sensor or float switch that lets you know wen full make sure unit is draining properly inernaly and full system is working properly
Jul 03, 2011 | Danby DDR7009REE Dehumidifier
Looking for replacement blower fan for Danby premiere DDR 7009 REE. The part is ABS D5304-130. Any help?
If your Danby humidifier is still under warranty, call 800-263-2629. If it's not still under warranty call
800-496-6049.
Hope this helped you. Please let me know. Thanks.
Jun 16, 2011 | Danby DDR7009REE Dehumidifier
I have a danby ddr7009ree humidifier which I am trying to drain with the hose in the back however water just keeps filling in the front bucket. I have removed the rubber plug from the back of the unit.
The continuous drain hole (where the hose is inserted) is clogged. To remove the clog, you will need an 18" long plastic Zip Tie (or something similar. But NO wire cost hangers) that will fit into the hole.
Insert it slowly and push until you reach a bend in the tubing. You will need to gingerly work it past this bend until the Zip Tie bottoms out or you run out of Zip Tie. Then, while rotating it, pull it out slowly. As you reach the end of the Zip Tie, be prepared for some water to follow. Also make sure that the drain hose, when reinserted is not crimped and the end is lower than the drain hose connection. The unit does not have a pump. It relies on gravity to drain water through the hose.
Hope this helped you to solve the problem. Please let me know. Thanks.
May 26, 2011 | Dehumidifiers
Hi Fixya: The Filter on my Danby DDR7009REE Room dehumidifier never seems to accumulate any dust. It is supposed to need to be cleaned every two weeks by vacuuming or soaking, but the filter is always...
How often does the unit run? Does the fan run when the unit is suppose to be running(as the fan pulls the air thru the filter). If every thing operates correctly and the filter is in the right location on the unit then all I can say is that you keep a clean house. Personally I only need to clean the air filter on my dehumidifier about once a summer. I wouldn't be overly concerned if it isn't getting very dirty.
Nov 10, 2009 | Dehumidifiers
My new Danby dehumidifier never shuts off
This unit is designed with the intention of the fan running all the time. The compressor cycles on and off with demand, however the fan runs continuously to provide constant room circulation.
Sep 14, 2009 | Dehumidifiers
Danby ddr7009ree - continuous drain won't work
I have the same Danby unit and the same problem. When you take out the water bucket look inside and find the two holes where the water drips into the bucket. These holes are approximately 5/16" and 3/8" diameter. These holes need to be plugged. Your local hardware store has an assortment of specialized parts boxes. Find the box that contains "corks" of various sizes. They sell for about 20¢ apiece. I bought 5 within that size catagory and two of them worked! Problem solved.
Aug 31, 2009 | Danby DDR6588EE Dehumidifier
Danby DDR7009REE Dehumidifier Logo
16 people viewed this question
Top Danby Dehumidifiers Experts
Vincent G
Vincent G
Sheldon Dedek
ADMIN Canada
ADMIN Canada
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
