Question about Lands Phones
Please help me change the external ringtone on a KX-DT543. All manuals show me, but it only works on internal calls. External calls still have the default ring and I can't find anywhere that helps.
Posted by Jess East on
Tom Chichester
    Top Expert:
  • Lands Phones Master
  • 61,334 Answers
The incoming ring tone is "fixed" to distinguish it from the various internal ringtones.
Posted on Jan 24, 2021
5 Related Answers
Gills1
Bill Gilhooly
  • 94 Answers
SOURCE: BT Freestyle 2200
I think the internal ringer is a default and cannot be changed, but the external ringer can be changed.e03e2a2.jpg
Posted on Dec 30, 2008
Anonymous
  • 37 Answers
SOURCE: ring tone for internal and external calls
this is a change your system administrator will need to handle, (or your phone tech). There is an option in the under "system options" called internal ring cadence for external callers; this is where you can have the system do a double ring for External and a single ring for internal or vice versa.
Posted on Oct 14, 2009
Testimonial: "It worked !!. Thanks !!"
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: I have a Panasonic KX-T7633 telephone. I need to
Rather than refer you, here's the quick answer. Press PROGRAM and the INTERCOM button twice. Now use the Navigator key up/down or dial 01-30 for the 30 different tones and press ENTER or STORE.
What was so difficult about that?
It also works for each SCO line button. You have to program each one on each phone.
Carl
Posted on Nov 14, 2009
Anonymous
SOURCE: Can't change ring tone on Panasonic KX-TCA175
I had the same problem. I was advised by Panasonic support that the PBX system needed a firmware upgrade to solve the issue. (still waiting for technician to do this...)
Posted on Jul 28, 2010
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: MY EXTENSION DOESN'T RING FOR
JUST AS YOU'RE TOO LAZY TO USE THE SHIFT KEY AND LOSE THE CAPS LOCK KEY, I'M TOO LAZY TO LOOK UP THELINK TO A MANUAL. HOWEVER, I CAN TELL YOU THAT YOU COULD GO TO THE PROGRAMMING MANUAL FOR A PANASONIC KX-TD 816/1232 AND LOOK AT DIL 1:N PROGRAM 603 AND 604. IT'S WHERE YOU SET THE EXTENSIONS THAT RING WHEN A CALL COMES IN.
Carl
Posted on Jun 23, 2011
How to remove FWD/DND FROM A PANASONIC KX-T7030X PHONE
Press intercom button
dial *71
choose the call forwarding type to cancel as follows
dial 0 for internal and external calls
dial 1 for external calls only
dial 2 for internal calls only
dial 0 to cancel call forwarding
press speaker to end
Jan 18, 2011 | Panasonic KX-T7730 Corded Phone
How do i cahgne the ring tone on the panasonic kx-t7565 phone. I have changed it but it only appears to have chagned if ring ring the number internally. we need the ring tone to change from external...
The ringtone for the CO or outside line buttons can be programmed by pressing program then press the
CO button twice, enter the ringtone you want by dialing 01 to 08, press enter or store then program to end. This will set the ringtone for that line assuming it is programmed to ring at that phone. Transferred calls will use the ringtone of the intercom button which can be set by the same procedure. Use the same procedure if calls ring to a Group Directory Number(GDN) on the phone. The 7600 series of digital phones have ringtone settings of 01 through 30.
Dec 15, 2010 | Panasonic KX-T7565 Corded Telephone
Apr 21, 2010 | Panasonic Lands Phones
I need different ringtones on my Nortel 7310
you should already, intrnal is double ring and external is long single ring. you can set sounds from the softkeys below display.
Nov 12, 2009 | Lands Phones
BT Freestyle 2200
Jun 26, 2008 | British Telecom Freestyle 2200 Trio...
Lands Phones Logo
14 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
