Question about Home Security
How do I change combinations Bulldog Cases Car Safe when they revert to default?
Posted by April Torres on
Connie Merrow
    Habit-Forming:
    Scholar:
  • 68 Answers
Changing combinations can be done from the reset button. It exists at the topmost part of the device. To reset - Hold it down for a few seconds until the light indicates green, release and enter your new preferred code. Repeat the procedure until the light goes red and re-enter the new code. Then repeat for a third time until the light gives you five blinks. TO know A depth review about this product You much visit here: Bulldog Cases Car Safe with Key Lock Review
Posted on Jan 20, 2021
2011 ford escape limited the remote start stopped workng
Remote starter in valet mode Symptoms: Lock and Unlock buttons work as normal, but pressing Start does not produce any response from the vehicle.
Causes: Someone accidentally pressed the combination of buttons to put the car into valet mode, usually when the remote is in a purse or pocket. Also, many remote car starters will revert to valet mode when the vehicle is disconnected for service.
Hood Pin Has Broken or Failed Symptoms: Pressing Start results in several flashes of the parking lights but no start. If equipped, Lock and Unlock still function.
Cause: In most cases, the under-hood pin switch is broken or corroded.
Remote Control Loses Programming Symptoms: Pressing any button on the remote results in no response from vehicle.
Cause: It is rare, but does happen - in most cases, this is caused by a dead battery in the vehicle or the battery having been disconnected when being serviced.
Remote starters usually have some type of non-volatile memory to retain things like programming features and remote control codes. Like any "computer" device, sometimes they lose memory. When this happens, simply call the store that installed it for you. In some cases, they may be able to tell you how to reprogram it over the phone. Other times, you will have to return to the store for a technician to program it. In any case, this is rare with higher-end remote starters.
Remote is in Second-car Mode Symptoms: Pressing any button on the remote results in no response from vehicle.
Causes: A combination of buttons were accidentally pressed, which put the remote in second-car mode.
Again, this is very rare, but happens from time to time. Many remote car starter remote controls have the ability to start two vehicles. If the remote is accidentally placed into second-car mode, it will not start or operate vehicle #1.
Simply read your owner's manual or call your installer for directions on how to revert the remote back to car #1.
Dec 08, 2016 | 2011 Ford Escape
Lsot combination
Hi RevelFreeman
Two directions you can go.
If you're the original owner of the safe, and you never changed the combination from when you got it, look in your documentation, call the manufacturer, or look online for 'My Safe Model / Type Default Factory Combination. That may well get you in, though you are strongly urged, in the process, to then change the combination and save a copy in a secure place. This process has ample history, including Richard Feynman cracking the safes with nuclear secrets during the Manhattan Project. It's also a TV trope, and well known to both the white and black hat types.
If you changed the combo to something else, your best bet is to dig up documentation that you are the owner of the safe (or, if it's built in, the owner of the house) contact a locksmith and talk to them about your predicament. No reputable locksmith will want to touch it if there's any question about whether its your safe and contents.
Hoping this helps, and Good Luck
D
Dec 18, 2015 | Home Security
Is there a default combination for brinks model 5054 safe
Contact brinks they may have a master code to unlock your safe...or try a good lock smith,they may have access to the code.
Jun 11, 2014 | Sentry FIRE-SAFE Combination Safe DS3431,...
My ZX 4951 screen is upside down and the Ctrl, ALT and Up arrow combination does not work. Any ideas as I cannot even login.
letl me get this straight
the image on the laptop screen is upside down?
turn off computer
press F8 for Safe Mode
hold down and turn computer back on
see how that goes
May 28, 2012 | Computers & Internet
Lost combination the protective executive safe
Contact the maker by phone to see if there is a way to recover or reset the combination---most safes have a serial or id number which will tell the maker what the default combination for that safe is.
FYI: you have this posted in tv section.
Apr 05, 2012 | Televison & Video
Factory reset la gard 3715 electronic safe
Welcome to FixYa.
How to reset or change your lock combination:
  • 1. Enter "zero" six times.
  • 2. Enter your existing six (6) digit combination one time. (or 123456, factory default if you haven't changed the combination yet.
  • 3. Enter your NEW six (6) digit combination two times.
  • 4. If a mistake is made wait thirty (30) seconds and repeat steps 1 - 3.
  • 5. Test lock operation several times before closing the door.
CAUTION: When selecting a combination do not use birthday or other predictable data that could give correlation between the user and combination.
• Valid Combination Entry - Double signal after valid six (6) digit combination is entered.
• Invalid Combination Entry - Triple signal indicates the old combination is still valid.
Thank you for using FixYa.
Have a great day.
Jas247
Aug 01, 2011 | Office Equipment & Supplies
Bulldog Deluxe500 in '02 trailblazer will not start or reset.
unplug all harnesses going to unit for 5 min plug all harnesses back in and reprogram remote, you do not need to program for voltage sense, that is the factory defalt or call tech support at 1-800-878-8007
Dec 16, 2009 | DLX 500 Remote Car Starter
I own a Bunker Hill digital floor safe sku #need code change data
To change the code: Your safe comes
preset with the default code of “159-A”.
To change the code, first open the safe.
On the inside of the door near the hinge,
there is a small red “reset” button. Press
this button until the Yellow LED on the
front panel lights up. Now, input your new
code up to 8 characters, followed by
either “A” or “B”. The Yellow LED will flash
to indicate that your new code has been
accepted. Warning: If the Yellow LED
does not flash, the code has not been
accepted, and you must start over.
NOTE: Be sure to test your new
combination before closing the door.
NOTE: Be sure to have the Override Key
available when setting a new
combination or changing batteries, in
case the door doesn’t open.
Good Luck
Nov 15, 2009 | Sentry Fireproof Safe
I want to reset the entry combination
Try and use default code 159a then try and reset if not go to harborfreight.com put in safe it has instructions on how to change all these are the same even if name is different
Oct 02, 2009 | Safe International Digital Electronic Safe...
Soft/hard reset combination keys doesnt work for nokia 6280
try this for soft reset
12345 is a standard code and 00000, but if you change it and you have forgotten your unlock code, you'll just have to reformat it
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot.
The trick is
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons...
reformatting your phone will delete all your data and also will restore all the defaults of your phone, and any corrupted application will be reinstalled, but if the formating doesn't work, you'll just have to re flash it, the safe way is to go to a near repair shop of your phone and have then to re flash your phone,
Mar 06, 2009 | Nokia 6280 Cellular Phone
Home Security Logo
14 people viewed this question
Top Home Security Experts
Marvin
Marvin
Tom Chichester
Are you a Home Security Expert? Answer questions, earn points and help others
