My speaker doesn't make any kind of sound when u plug in aux cord like other one does...its like speaker came undone or something...how do I get to speaker wire to make sure its still connected
Posted by Terry Bradley on
5 Related Answers
Anonymous
SOURCE: Stereo volume doesn't effect Aux input volume
in a car stereo system, when you select line input, it usually assumes the device you are connecting has its own volume control. if you really want to use your cars volume knob, an FM transmitter might do the trick.
Posted on Dec 19, 2007
Anonymous
  • 76 Answers
SOURCE: TV Sound through stereo speakers while watching tv.
All the above connected method is correct. Need to change the option in the stereo system as md or auillary depends upon the model. Go through user manual for stereo system.
Posted on Jun 24, 2008
john adams
  • 5 Answers
SOURCE: Aux cord is broken
Do you have soldering tools? If so cut strip solder LIGHTLY tape it up and see if that does it.
New or replacement radio shack maybe
BA wep site and the usual e bay craigslist
b
Posted on Oct 31, 2009
Anonymous
SOURCE: brother tripped over cord connected to laptop
TandN-
if you want a fix rating then why don't you try to fix the problem then...
I have the same problem, from what I've read, we need to buy a complete replacement of the wired remote. I still can't find anything, but I'm about to call logitech and see what they say.
Posted on Feb 25, 2010
jose_v17
Jose Velazquez
  • 229 Answers
SOURCE: how do i connect an aux cord to my head unit...
You can go to radio shack and grab a 3.5mm to 3.5mm cable. make sure that is male -to - male. Some decks are equipped with an AUX IN in the front and some in the back and then some have both. This wire will resemble the same input end of an earphone plug. Once you have your device plugged in then just press the SRC button on your deck till it says AUX, AUX IN, or Audio. Let me know if this helps
Posted on May 22, 2010
Speaker turns on but no sound. If i plug into aux cord it workes
check the speaker wire is your music player is connect properly. if not work something wrong your sound ic or speakers, aux port means that any other items plug in socket,ex mobile phone or dvd players , mini disk player
Feb 07, 2018 | Audio Players & Recorders
Sentry 2.1 surround sound speaker system. i have my rca cords plugged in to my tv, but i only get sound from my tv, nothing out of the speaker itself. it only works when i have my headphone jack into
Most televisions have a setting that controls whether the TV uses its internal speakers or sends the sound to the audio out jacks for an external amplifier or speakers.
Try going through the settings menu and follow through the audio/speaker selections and confirm that the TV is set to use external speakers.
Best Regards,
Sep 01, 2017 | Televison & Video
I'm plugging in an active speaker to aux 3 of my fx16ii, but it doesn't work. I have it set up the same as aux 1 and 2 where I'm also running active speakers (for monitors). Am I missing...
If you look at the signal flow diagram in your user manual, you will see that while AUX 1 and 2 can be selected are PRE or POST fader, AUX 3 is POST fader only... this means that the channel faders control the AUX3 level as well as the aux out level. Make sure you use TRS balanced lines to your speakers and not TS cables.
Sep 02, 2011 | Soundcraft FX16ii 16Channel Audio Mixer
I'm trying to plug an active speaker into aux 3 for a third monitor mix but it doesn't work (I do the same with aux 1 and 2). Am I missing something? Cheers,
I answered another post of this earlier. The AUX3 is strictly POST FADER... you MUST turn the channel sliding fader up to send signal to AUX 3. Also the AUX3 channel gain KNOB must be turned up. Also the AUX master gain KNOB must be turned up. Make sure your cablles are balanced TRS cables from the mixer to the powered speakers.
I JUST bought a insignia speaker 2.1 (model # NS-PCS21) and the speaker plug ins are pluged right, power are plug in, the green and the red cord plugged in... i see blue light comming up. my computer sound...
Greetings - The setup (as you already know) is simple. If you have the a/c adapter plugged in, the power on and the green speaker cable in the audio out at the back of your PC and and the red cable plugged into the subwoofer and the volume knob on the the right speaker turned up that's all it takes.
The one possible gotcha I can see is if you have something plugged into the jack at the BACK of the right speaker (an AUX jack for things like MP3 players, etc.) it will override everything else.
If that's all good you have a bad set of speakers.
Regards,
Mikeywaf
May 30, 2011 | Insignia 2.1 Speaker System (3-Piece)
How do I use altec lansing acs40 with a laptop?
Fairly easy really. You'll need to buy a jack to jack AUX cable. Single point for stereo needed and a headphone jack on the laptop.
The left hand and right hand speakers are slightly different. The right hand speaker only has a cord coming out the back of it and no AUX points.
The right hand speakers has a series of small jack points.
The first hole is the adaptor plug that has to be plugged into mains socket, then the 1st hole marked SPKR has to have a jack to jack cord going from that speaker to the other one. The last two holes marked "A" and "B" give you the option to put two jack to jack AUX sound cables in.
To get it into your laptop, you'll need ONE AUX jack to jack cable and fit it into the point at the back marked "B" and then through the headphone socket on your laptop. You will then have sound.
Make sure to remember to put the system on by the push button switch on the back of the left hand speaker. The speaker system also has another rotary switch on at the front of the speaker.
I've had these speakers for well over 10 years - brilliant sound quality and very durable. Hope it has helped you!
May 04, 2010 | Altec Lansing Multimedia Computer Speakers
Very little sound coming from driver side front and rear speakers, checked the balance and fade nothing is helping.vehicle is 2003 hyundai tiburon with infiniti sound system
the chance is maybe the speaker is blown, or wires crossed, if it is an aftermarket head unit, and or you use an aux cord to listen to an ipod or something like that as your music, that is most likely the auxilary cord is bad or cheap, happened with my car also
Jul 27, 2009 | Car Audio & Video
Need aux cables
Try your local pc shop or something like Radio Shack
Jul 11, 2009 | Altec Lansing ADA 885 Computer Speakers
15 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
