You have lost gas (hissing), you need a refrigeration engineer
GDM-41SL-54-HC-LD - Retail & Display ' True Manufacturing ...
www.truemfg.com > Glass-Door-Merchandisers > GDM...
GDM-41SL-54-HC-LD. Glass Door Merchandiser. Compare. Description, Product Specs, Files & Downloads, Product Video. The world's #1 manufacturer of ...
True GDM-41SL-54-HC-LD 47" 2 Sliding Glass Door ...
www.nellaonline.com > products > true-gdm-41sl-54-h...
True GDM-41SL-54-HC-LD 47" 2 Sliding Glass Door Merchandiser is designed with the highest quaity material ensuring long-lasting durability. The LED lighting ...
Posted on Jan 20, 2021
SOURCE: Fridge stopped working suddenly
Sounds like the relay (start device) on the compressor has failed. This is a very common problem especially for models that are 3-5 yrs old. I would replace that first.
Posted on Oct 22, 2007
SOURCE: Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
Ended up having a freon leak in tubing around door. Luckly the warranty was 5 years in sealed system. New one was FREE.
Posted on Feb 23, 2008
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Posted on Jun 09, 2009
SOURCE: Indoor unit temperature between 60F & 70F after R22 charge..
If anything, it appears undercharged. Purging is not recommended. @90 degrees the high side corresponding pressure is 168.4 and Low side coresponding numbers re70psi/68degrees. With all due respect to the tech I think . If your room temp is 80, the corresponding high aide pressure is 143.6 , Low side 85 psi Yup, undercharged. Now do me a favor and don't start any "but he said" wars going. If anything, Just call him back and tell him something is still not right. Ask him to bring you a pocket rergerence for temp/pressure relationships. The numbers I gave you are for R-22 which is commonly used in residential applications. Well, good luck and keep your cool. IDon't purge. R-22 is very expensive asis everything else. You may want to dispute anny additional service call charges. Good Luck
Posted on Aug 22, 2009
SOURCE: My Vinotemp VT52SN stopped cooling.
How To Test the Compressor Relay
The compressor relay's purpose is to
start the compressor. A faulty relay can result in the compressor
failing to cycle on. The relay is accessed from the lower rear of the
refrigerator the
relay is located in the terminal box which is located at the side of the compressor.
Before testing a compressor relay, unplug the refrigerator to avoid
an electrical shock hazard. Also, if the compressor uses a capacitor,
it must be discharged first to avoid the risk of electrical shock.
Beneath the terminal cover is found the compressor relay , overload protector and the electrical
terminals of the compressor motor.
Remove the compressor relay by pulling it straight off from the compressor.
Pull the wire off of the side terminal of the relay. It is connected
with a slip on connector. Firmly pull the connector, do not pull on the
wire. You may need to use a pair of needle-nose pliers.
Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced.
There are two types of relays you may encounter, wire coil and solid
state. If the relay has an exposed wound wire coil it can be tested for
continuity. Otherwise, the relay is of solid state design and requires
specialized equipment for testing.
Posted on Jul 08, 2011
Aug 01, 2018 | Honeywell Heating & Cooling
Sep 28, 2016 | 2002 Dodge Ram Pickup 1500
Mar 28, 2014 | True Refrigerators
Jan 11, 2011 | Heating & Cooling
Dec 19, 2010 | Heating & Cooling
Dec 07, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Jul 10, 2010 | Goodman CLQ36AR49 Air Conditioner
Jan 17, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Aug 11, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Apr 19, 2008 | Heating & Cooling
12 people viewed this question
