Question about Cell Phones
I have a hisense tv, sometimes it will connect to the hotspot from my phone but most of the time it won’t. And now it’s saying wireless module is not inserted, insert the wireless module
Posted by Kay Dunk on
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: phone says insert sim and sos calls only
parck the simm
Posted on Feb 28, 2009
Anonymous
SOURCE: says insert smart chip
It is possible to put the sim card in backwards.  My daughter did and when we turned it around I no longer got the "smart chip" error message.
Posted on May 31, 2009
Anonymous
  • 74 Answers
SOURCE: phone says insert SIM card, but it is in the phone
the sim tray may be faulty
Posted on Nov 21, 2009
Anonymous
SOURCE: Sony ericsson w995 won't charge. On attempting to
my sony ericsson w995 wont charge off mains or usb cable any ideas
Posted on Mar 08, 2010
emmy spa
  • 277 Answers
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Posted on Aug 16, 2010
How do I connect my hotspot from my phone to my tv
on phone go to settings > wireless&networks > hotspots & tethering > then activate hotspot and set hotspot password, turn on tv wifi adapter and input hotspot password to connect.
Jan 07, 2016 | Cell Phones
How do I get my tablet connected to mobile data?
Most cell phones have a built-in wireless hotspot option. On Android, go to Settings, under Wireless and Networks there should an option for Tethering & portable hotspot, setup the hotspot settings first, then turn on the hotspot, and make sure your 3G/4G/etc data is enabled, then have your tablet connect via wireless to your phone's hotspot and you're good to go. Good luck.
Dec 04, 2014 | Tablets & eReaders
How can I connect my hisense tv to wifi? it wont show my wifi name in security mode. when I scan it says no ap?
Either your router is not set up to broadcast the SSID(network name),the router is too far away from the TV, or there is a problem with the wireless on the TV.
If you can see the SSID from the same location with your phone/tablet/etc then it is probably an issue with the TV. You can also check for a firmware update for both the TV and the router.
Nov 16, 2014 | Hisense Televison & Video
How can i connect to fb on my hisense smart tv using my cell phone
Through hotspot on your phone wifi connection but tv may not be wireless
Sep 29, 2014 | Cell Phones
How do I connect my TV to the wifi
The TV must be in range of your wireless router in order for the TV to connect. You have to put the wifi password in the TV and sometimes the mac address of the TV into the wifi section of the router
Sep 11, 2014 | Hisense TL1700 17 in. LCD Television
Using my phone as mobile hotspot how do i get my network ssid.
You can use your Android phone as a portable hotspot and get your iPad, iPod Touch, or any other wireless device online. This is a great save when there are no available wireless connections available.
1. Go to the Home screen.
2. Select the Menu key.
3. Select Settings.
4. Select Wireless & networks.
5. Select Tethering & portable hotspot.
6. Select Portable Wi-Fi hotspot checkbox.
7. Select Portable Wi-Fi hotspot settings.
8. Select Configure Wi-Fi hotspot.
9. Input a Network SSID for your connection.
10. Select a security protocol. Options are Open andWPA2 PSK.
If you select WPA2 PSK, input a password for the connection and then select the Save button.
You will use the Portable Wi-Fi hotspot checkbox from above to enable and disable the connection. Once the connection is active, go to the device you wish to connect and configure its wireless connection to the Network SSID for you Android device and input the password (if you are using WPA2 PSK). You now have wireless access for your iPad, iPhone Touch, Zune HD, etc. anytime there is a cellular connection for your Android phone.
Aug 08, 2014 | Cell Phones
3. Select Settings.
10. Select a security protocol. Options are Open and WPA2 PSK.
-regards and update me
O2 wifi hotspots not working
The dns info is provided via DHCP which is given out by the hotspot. You may want to A) try and simply reboot the phone and B) go into your settings > wireless and press and hold on the hotspot SSID (wireless name) and forget it. Then re-connect. Otherwise I would say it's an issue with the hotspot.
Nov 23, 2013 | O2 Cell Phones
O2 wifi hotspot no dns
The DNS info is provided via DHCP which is given out by the hotspot. You may want to A) try and simply reboot the phone and B) go into your settings > wireless and press and hold on the hotspot SSID (wireless name) and forget it. Then re-connect. Otherwise I would say it's an issue with the hotspot.
If you need to check any DNS query for website visit the site WhoisXY.com .
How do I use the mobile hotspot to connect to my Dell laptop
Depending on your phone make and model, there should be an option that says something like mobile AP or Hotspot, you set this up, give it a name, security method and password, and thenm activate.
then on your laptop activate the wireless look for the name of your AP or hotspot and connect to it with the password you used.
also note that most phone use a Automatic IP address to connect to internet, so the IPv4 has to be set to Auto...
if the dell connects to phone but not to the internet I would say its the IP settings,,
Hope it helps
Feb 15, 2012 | Computers & Internet
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
