Not going to work. That remote is for a DVD, and not reprogrammable.
this is your Sony Remote
Used General Replacement Remote Control For Sony KV ...
www.amazon.ca > Replacement-KV-32S40-KV-32S42-...
Used General Replacement Remote Control For Sony KV-32S4 KV-32S40 KV-32S42 KP-V46S55 KP-XBR48 Plamsma LCD LED HDTV TV television: ...
SOURCE: My sony Trinitron KV-32S42 keeps blinking on and off
This can be a symptom of the picture tube starting to fail or a power supply problem. Can you please verify the model number and I'll then be able to give you a few options.
Thanks,
Dan
gemni3 quick 50 codes for samsung tv
SOURCE: need remote codes for Sony trinitron kv-27s66
I have the same T V and i used the code 11100 and it worked . Give this a try and it should work. for T V Sony Bravia lcd
SOURCE: RC codes for ge-24914-d to control sony Trinitron TV KV-27S42.
the codes for sony are 0128, 0013, 0002, 0071, 0380, or 0152
1) Make sure the tv is on.
2) Press and hold the set up button till the red light on the left hand corner stays on.
3) Then press tv then release quickly so that the red light flashes once. (its pretty quick so pay attention).
4) Then enter one of the four digit codes and the red light will turn off.
5) Then press channel up.
If it goes up u have the right code. If not start from the begining (holding the setup button down) and do the same steps for each of the codes, one of them should work if not u have to do a code search. Follow steps #1, 2, 3, and 5 but on step 5 press it repeatedly (for up to 300 times and it says that on the instruction manual) until the device can be controled. The red light blinks then stays lit
6) press and release mute to install the code. The light will go off.
