SOURCE: Advent ADE 210C
There is no easy way to tell you this. The smaller speakers usually plug into the large speaker. The large speaker is the sub and has a power source for the other speakers.
I
can't fix this for you, but if I helped you get it fixed, please rate it as a
fixya not a helpful rating. These ratings let me be allowed to help you
and others in the future.
SOURCE: Woofer not working
If you can open the cabinet of your woofer box please check all the wires connected to the woofer and use a multimeter to check the continuity of woofer coil.If shows no continuity replace the woofer
SOURCE: front right speaker is not working
This may sound obvious, but have you plugged in all the plugs?a 4-channel sound system has two plugs that plug into the sound card.One is for the front speakers and part of the subwoofer, the other is the rear speakers and the other part of the subwoofer. AC97 audio normally supports only 2-channel.s your sound on-board?how many sockets does it have.A common AC97 normally has a green plug (for 2.1 speakers), a blue one for line in and a red one for a mic.A four-channel one will have a black socket for the other two speakers.and 5.1 has a yellow socket for the 5th speaker and woofer.
If your AC97 audio does not have the black socket, then you will need to buy a special card, like the Sound blaster 4.1 Digital (around £20-30).Or, if you want a 5.1 card, the Creative Audigy is considered the best, as the Audigy 2 is still expensive, and there are cheaper cards for 4.1.
Hopefully this should sort out the problem.I also have Creative Inspire M4500 4.1 speakers, and they have 2 plugs.
