Where can I find an owners manual for a Mainstay 26 Freestanding Wood Mantel Fireplace Heater, model FP404RN? It was a gift and I have no remote control.
Posted by Red Cossack on
5 Related Answers
Anonymous
SOURCE: Buying A Owner Manual (&) Remote Control for Toshiba VCR M752
Manuals for Toshiba VCR's (including the M752) are available here:
Toshiba VCR Manuals
Posted on Jan 28, 2008
bhiga
Brandon Higa
  • 119 Answers
SOURCE: distance over gas fireplace
Both LCD TVs and plasma TVs get hot, though plasma TVs tend to be a bit hotter in my experience. Also, plasma TVs are going out of fashion.
A lot will depend on the construction of your fireplace. If it's brick it should insulate fairly well.
Either way, I would recommend a mounting solution that does not put the back of the TV flush with the wall. Get one that tilts. I would avoid the "arm" style ones as that will put additional strain on the mounting.
Remember to think about how you want to run your power and video cabling as well!
Posted on Apr 07, 2008
Paul Carew
  • 3534 Answers
SOURCE: remote control working with fireplace.
try www.dimplex.com go to customer sevices they should be able put you on to a local dealer in your area
hope this is of some help
Posted on Dec 13, 2008
Anonymous
SOURCE: Need manual for Charmglow vent free freestanding fireplace
i have a manual, if you would like a copy? do you know if it can be converted to Propane?
thanks,
Rand
Posted on Jan 08, 2010
Anonymous
SOURCE: My Dimplex freestanding electric fireplace, model
Heater keeps turning off and on every few seconds
Posted on Jan 06, 2011
How to put the mantel and flue parts back on in the fireplace
Fireplace and Chimney Parts: Diagram and Anatomy
https://www.highschimney.com/.../parts-chimney-anatomy-fireplace-chi...
Nov 30, 2011 - A chimney is made up of up to 22 parts. ... Mantle - Also known asmantel piece or mantel shelf, this piece of hardware is more than a .... I have an old Blaze King Fireplace Insert that was purchased back in the mid 1980's.
How to install a wood burning fireplace insert - Hearth.com
www.hearth.com/econtent/index.php/articles/install_insert
A Heatform is a metal firebox which is built into a full masonry chimney. ... The distance to the adjacent wood trim and the mantle. ... All the way back in the fireplace, or out on the hearth? ... Rockford Chimney Supply - We are the best source forChimney liners and Stainless steel chimney liner kits to install your insert or ...
Dec 20, 2015 | Heating & Cooling
The fireplace no longer produces a flame, i do not have the manual to trouble shoot and fix it
Gas Fireplace Manual - Gas Fireplace Instructions: Mendota ...
mendotahearth.com/gas-fireplace-stove-owners-manual.php
Mendota gas fireplace manuals and gas fireplace instructions for Mendota ...Mendota Gas Fireplace Insert FullView Model FV33i PF2 - Installation Manual
[PDF]FIREPLACE HEATER - Crane
crane-usa.com/assets/.../Fireplace_Heater_2013.pdf
by C Care - ‎Cited by 2 - ‎Related articles
your fireplace heater, please contact Crane. Customer ... This instruction manualapplies to the following models of the Fireplace Heaters product line: Color.
Nov 29, 2015 | Heating & Cooling
I purchased a mantel fireplace from Fingerhut last March. The name on fireplace is FEBO FLAME. Now the on switch lites on but theres no flame or heat. The buttons on fireplace or remote do nothing. Id...
Since it can be a potential hazard, it must have safety protocols in place. If you have the owners manual, Read it's instructions carefully. Look through manual for TROUBLESHOOTING then look for safety locations, there you should find all the answers to your questions. Good Luck too you.
Jul 05, 2017 | Heating & Cooling
My electric fireplace won't come on. We changed the light bulbs. Nothing will work. What do I check now
https://www.heatsurge.com/help/service-store-locator
Customer Service
1-800-924-7964
Mon - Fri: 8:00am - 9:00pm EST
Sat - Sun: 9:00am - 6:00pm EST
[email protected]
Dec 09, 2012 | Leisure HOMEPRIDE Electric Fireplace...
How do we install a burner on a fireplace?
Thinking of adding a fireplace or wood stove to your home? If so, proper installation and maintenance is absolutely critical to ensuring the fire stays inside your freestanding fireplace or wood stove and doesn't venture outside of it.
If your manufactured home already has a fireplace or wood stove, it's a good idea to go look over these safety guidelines to confirm that it was installed correctly. If you plan to install a fireplace or wood stove, follow these safety guidelines carefully.
First, don't try to tackle this project yourself. While installation manuals usually provide all the instructions necessary for a manufactured home owner to install a wood-burning fireplace or wood stove, the consequences of a mistake are so disastrous, it's a task best left to experts.
It's a good idea to first check with your insurance company for their guidelines before installing these items. Your insurance policy may not cover damages if a fireplace or wood stove was not professionally installed. Plus, the manufacturer's warranty on the fireplace or wood stove may not apply unless the unit is installed by a professional.
Also can check this ARTICLE for other details.
Hope helps.
Jun 02, 2010 | Heating & Cooling
How change a Marco Fireplace from wood burning to gas logs
HI best get as gas fitter in to look at this and see if it can be done safer bet
Dec 14, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Marco gas firplace
I have a Model 792864B. Before you attempt to light the pilot light - make sure that any wall control switch or remote control for the fireplace is in the off position. Locate the gas supply line. There should be a gas supply valve to turn on the gas supply. The valve is usually painted a different color than the supply line like blue, green or yellow. Open the valve by pivoting the handle to be parallel to the gas line, usually counter-clockwise. When it is closed it is at a 90 degree angle from the supply line. Locate the pilot light assembly - this is the pilot light. There should also be a red or black ignitor button and a black or green valve control knob with the words "on" "off" and "pilot" on it. It may be located inside a black box, mine is marked heatolator, that has a lift off top. Lift off the top of the box. Push in the valve control knob and turn it until the word "pilot" is in line with the arrow (my arrow is red) or indicator line. While pressing and holding in the valve control knob - it presses in about 1/4", press the red or black ignitor button repeatedly (once per second) until the pilot ignites. Once the pilot is lit, continue to hold the valve knob in for about 30 seconds and then slowly release. The pilot should remain lit. If it remains lit, press in and turn the valve control knob to the "on" position. The on/off wall or remote control switch should now light your fireplace. If the pilot doesn't ignite, turn off gas supply valve, wait about 5 minutes and try it again.
Nov 20, 2007 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
