I got a Toyostove L-60AT Heater and was wondering if I could get it out of Fahrenheit and into Celsius. I’ve tried looking around everywhere on the machine and can’t find anything, and I’ve looked at the manual and can’t find anything saying how and I’ve looked around online so just wondering if anyone knows if it’s possible to change and if anyone has a solution
Posted by Rio J on
5 Related Answers
catriver
Ron Marek
  • 878 Answers
SOURCE: changing panel from fahrenheit to celsius
Dawn, press the refrigerator key and freezer key together for 5 seconds. It should toggle between them. Catriver.
Posted on Dec 25, 2007
Anonymous
SOURCE: changing the oven from celsius to fahrenheit
You will need to push the broil button down for at least 10 seconds then you will see the c change to a f for farenheit
Posted on Nov 06, 2008
Anonymous
SOURCE: change from celsius to fahrenheit
Don't listen to 'nitrousaura' (what a maroon, as Bugs would say).
Anyway, the way to change between Celsius and Fahrenheit is to hold down both the 'Temp down' and the 'Amb' buttons for 5 seconds. Be sure to do the 'Temp down,' not the 'Fan down' like I tried the first time and had to call Kia back. :) The two buttons are on opposite sides of the display.
Will
Posted on Jan 31, 2009
Anonymous
  • 4 Answers
SOURCE: Can't change my thermostat from fahrenheit to celsius.
When you do your system setup, Function 320 controls your temp. format. Set Function 320 to 1(celsius); Then press DONE. This will solve your problem.( Function 320 is defaulted to 0-Farenheit).
Posted on May 05, 2009
bschilz
Bill Schilz
  • 2049 Answers
You can switch the temperature mode between Fahrenheit to Celsius as follows:
While depressing the AUTO button, depress the OFF button for 3 seconds or more. The display will change from Fahrenheit to Celsius, or from Celsius to Fahrenheit."
Posted on Feb 03, 2010
Converting 14 degrees c to f
To convert degrees Celsius to degrees Fahrenheit, you multiply by 9/5 and then add 32.
For example, 0 degrees Celsius would be 32 degrees Fahrenheit.
Another example, 100 degrees Celsius would be 212 degrees Fahrenheit.
14 degrees Celsius would be 57 degrees Fahrenheit.
Good luck,
Paul
Jan 05, 2017 | Office Equipment & Supplies
Tip
C++ Source code for Celsius to Fahrenheit
#include <cstdio>
#include <cstdlib>
#include <iostream>
using namespace std;
int main(float nNumberofArgs, char* pszArgs[])
double celsius;
cout << "Enter the temperature in Celsius:";
cin >> celsius;
double factor;
factor = 212 - 32;
double fahrenheit;
fahrenheit = factor * celsius/100 + 32;
cout << "Fahrenheit value is:";
cout << fahrenheit << endl;
system("PAUSE");
return 0;
on Jun 16, 2010 | Computers & Internet
What is the fahrenheit eqivalent of 20 degrees celsius
Hi
To convert temperatures in Celsius to Fahrenheit:
Multiply by 1.8 (or 9/5) and add 32.
  • Your answer: 20°C x 1.8 + 32 = 68°F
Trust this helps, regards Alan
Jul 07, 2014 | Comfort Zone NEW 09 Electric Portable...
Electrolux ewx14440w washer dryer will not heat water
Hello - Hot water is most often 10 degrees colder when it arrives at your machine from when it leaves your hot water heater. In general hot water is 130 degrees Fahrenheit (54.4 Celsius) or above. Warm water is between 110 and 90 degrees Fahrenheit ( 43.3-32.2 Celsius). Cold water is generally between 80 and 60 degrees Fahrenheit (26.7-15 Celsius). If cold water is below 60 degrees Fahrenheit (15 Celsius), clothes are unlikely to be cleaned very well. After confirming information and it proves to be ineffective contact a professional to move forward accurately. Unit could possibly be experiencing a defective timer, temperature sensor, or water valve.
Oct 28, 2012 | Electrolux EW1000i Front Load Washer
I have a red core heater how do i get from celsius to farenheit
Press the Temp UP and DOWN buttons at the same time and hold for about 3 seconds to toggle between Celsius and Fahrenheit measurements.
Oct 21, 2012 | Cars & Trucks
Water too hot
Jul 20, 2011 | Washing Machines
Change temperature from Celsius to Fahrenheit on a comfort zone h
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release. - VS
Nov 11, 2009 | Comfort Zone CZ-800 Heater
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
