Question about Canon PIXMA MG7120 Wireless Color All-in-One Inkjet Printer
Mg7120 won't print because "low or no ink in cartridge". The grey cartridge had run out and was replaced.
Posted by James Petrarca on
5 Related Answers
jazzpolice
SOURCE: Lexmark P6250 black ink cartridge won t print
Write to Lexmark - you won't get any joy, but their reply might be interesting. I suspect that Lexmark builds a chip into their cartridges preventing it being refilled. When replying to me they did not admit this, but did not deny it, simply stating that their cartridges were designed for single use only. When I said that, apart from the cost, I wanted to minimise my impact on the environment by refilling cartridges, they pointed out their proud association with Planet Ark. I suspect that Planet Ark is happy to be an apologist for corporate vandals, and I seriously question their 'green' credentials. Order your next cartridges from Europe where the printer companies are not allowed to chip their products.
Posted on Sep 02, 2007
Anonymous
SOURCE: HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Posted on Oct 22, 2008
Anonymous
  • 4 Answers
SOURCE: installed new ink cartridge/ still saying low color
try calling 1 800 421 6699 for US.
solution
try to remove inks, then reseat it..
then remove printhead, by pushing the latch on the upper right, then put it back in. be sure that it will snap. close the door with no inks. try to look at the message, if it has the same error, put the inks on it and close the door again.. then if you still have the error message, call the hotline no. and I'm Afraid that you need a Printhead replacement or defective ink issue...
they will replace it for free..
Posted on Feb 10, 2009
J Anderson
  • 159 Answers
SOURCE: replaced ink cartridge and it still says low ink
There is no way to reset the ink levels on this type of cartridge. Therefore, your printer will always think refills are empty. You can choose on the dialogue box to "ignore ink levels" and run the cartridge until it is empty. This is just one thing you will need to deal with on refills of this cartridge type.
Posted on Feb 03, 2010
pineworks
Clive
  • 4345 Answers
SOURCE: won`t recognize new ink cartridges
Hi there
There are only a few steps you need to do to reset a Brother printer ink cartridge and once you do it, you will be up and printing in no time. There are actually two things that a Brother printer uses to detect ink and you can manipulate one or the other.
Instructions
Things You'll Need: · Black electrical tape, masking tape or duct tape
1. Step 1
Identify the printer If your printer uses memory, you can tell which printer you have by looking at where the cartridge goes in, if you see two "eyes" and a part of the cartridge goes in between them, follow Step 3. Otherwise, continue with Step 2.
2. Step 2
Clear the memory by taking the cartridge out and unplugging the unit for 30 seconds. Then, plug it back in and put back in the cartridge. You may need to do this five times, as the memory holds the last five cartridges.
3. Step 3
If the Brother printer has "eyes" where the cartridge goes, you will need to block in between them with a piece of tape so that it thinks the cartridge is always full. Simply put a piece of tape on the piece of the cartridge that goes in between the eyes to block the path of the infrared beam
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 03, 2010
Mg7120 won't print black on paper,but will print pictures with black just fine
It looks like you may have 2 black ink cartridges; one for black-and-white printing, and one for color printing. The larger one may have clogged nozzles. Run a cleaning cycle several times, and see if that solves it.
Other options which would be entirely at your own risk:
1. Dabbing the print nozzle head with warm water on a cotton swab.
2. As above with a mild solution of rubbing alcohol.
3. Soaking the print head overnight.
4. Applying vacuum to the print head.
Feb 11, 2017 | Black Office Equipment & Supplies
Not printing any black text on paper.
Following Occam's Razor, the first thing to do would be to replace the black ink cartridge.
May 23, 2016 | Canon PIXMA MG7120 Inkjet Multifunction...
I have a HL4040CN copier. When the message comes up that ink is low, how can I tell what color ink cartridge needs replacing
You're just going to have to keep printing until you see which cartridge is getting dry. It'll be either the black one or the colour one. This way you won't buy the wrong cartridge. If you print black text and it starts to come out grey then it's the black cartridge that needs to be replaced. The same with colour, if the picture looks faded then you'll need a new colour cartridge.
May 11, 2011 | Brother Office Equipment & Supplies
I don't know how to change the ink cartridge of epson tx 110
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
SEE IMAGE BELOW
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Mar 21, 2010 | Epson Office Equipment & Supplies
When i print a black and white picture from computer it prints pinkish
Have you checked your ink levels? There is a low ink utility with HP printers that should read the ink level of the Black or Grey cartridge.
If the levels are up, then run the maintenance and nozzle check for this printer through the Print menu.
Jan 14, 2010 | HP Officejet 6310 All-In-One InkJet...
HP psc 2110xi color printing problem
The printer head may need to be cleaned. You can buy a cleaning kit for the head.
May 08, 2009 | HP PSC 2110 Color Printer
Colours are not true, grey is brown
You are getting leakage from one color cartridge to another. Do deep cleaning and run nozzle check. You may have been using non-Cannon inks. They can corrode the ink cartridge seats due to inferrior quality ink. You may need to replace the print head. Check out Cannon web site under this printer support. Print head is in the $50 neighborhood.
Feb 10, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Want to print with black ink cartridge only
It is a little known fact that ink cartridges do have an expiry date, and it is sometimes possible that even if a printer reads full, that it has dried out and will not print. When you recieve a warning that your ink is too low you will simply be unable to print black ink after a certain point. Generaly if you want to print in only black you will have to do that when you print a document. For instance in IE when you go to file and then print you can select prefrences and select print in greyscale or black. hope this helps!
Jan 24, 2009 | Dell 922 All-In-One InkJet Printer
Canon i560 won't print properly after ink reload
try to clean nozzels and run the alignement utilityt.
Jan 21, 2009 | Canon BubbleJet i560 InkJet Printer
Canon PIXMA MG7120 Wireless Color All-in-One Inkjet Printer Logo
13 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
