Question about Whirlpool Washing Machines
SOURCE: Singer Starlet 353 Thread tension
you need to do a tension assembly check.
Normal 0 MicrosoftInternetExplorer4
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}Tension assembly test. To do this test. Pull the threadthrough the tension assembly and test it to make sure the tension is workingcorrectly.
(To do this test, adjust your tension setting to normal or medium or 5 orsomething in the middle. Raise the presser foot and pull the thread through thetension. It should pull easily!! Lower the presser foot and pull the thread. Itshould pull noticeably harder.)
If it doesn’t work this way then you probably have a pieceof thread or lint stuck inside the tension discs. To remove it, turn thetension to 0 zero and raise the presser foot.Using a small screwdriver, openthe space between the discs and spray with canned or compressed air. The stuffshould come out. Do the tension test again to make sure you got everything andthen try sewing again.
sewman7
Posted on Nov 07, 2008
SOURCE: Remove lid of top loading washing machine Kenmore 110.92575110
Remove 2 screws that hold the console in place. Most are at the rear corners of the console. Pull console forward and up and tilt back.There are 2 brass clips holding the cabinet in place. then the cabinet can be removed by tilting forward and away from base. there is no reason to remove the lid.
Posted on Jan 05, 2009
SOURCE: replace rear turn signal bulb on 2007 H3 - driver side
1st::Unscrew the 2 screws that hold the light in.
2nd::Slide your hand behind the light and pull the light towards you. Make sure that you pull it straight, as if the h3 was driving away from you, so you dont break the two pins that are holding the light in...PULL ONE PIN AT A TIME!!!
Dont pull it to far away from the hummer as there are wires attached that need to stay attached.
3rd::turn the back of the bulb to unlock it from the lens...
4th:: slide the bulb out and remove thebulb by pulling it straight out.
5th::put the new bulb in, lock it back into the lens, then insert it back where you got it from,...
MAKE SURE you move the wires out of the way when you put the lens back in...they will get in the way and can be damaged.
Posted on Apr 07, 2009
SOURCE: Whirlpool Front Loading Door leaking water
The most common cause for a front loading washer to leak from the front door is a torn or detached gasket where that gasket attached to the machine.
Open the door and begin to pull the gasket away from the opening. Look for any problems. If you find a place where the gasket is not firmly secured to the opening, you can list that area up and glue (even with super glue) the gasket back down to the metal opening.
If you find gasket damage, it will need to be replaced.
Posted on Jan 03, 2010
SOURCE: Error code F13 is showing
Check
mechanical linkage from dispenser motor to the top of
the dispenser.
Check
Wire Harness connections to the dispenser motor and Central
Control Unit (CCU)
Check
Dispenser Motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 07, 2010
Sep 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sep 07, 2010 | Whirlpool AWOE8748 Front Load Washer
Jun 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
May 11, 2010 | Whirlpool AWOE8748 Front Load Washer
Feb 15, 2010 | LG WM-2277HW Front Load Washer
Nov 10, 2009 | LG WM-2277HW Front Load Washer
Nov 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sep 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Jun 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
May 13, 2009 | Whirlpool LSR6332K Top Load Washer
23 people viewed this question
