Question about Candy Ovens
Model FPE 609A/6XL. When I use it, why does it stop and Er. 6 appears?
Posted by Sofia Joe on
David Spradling
    Top Expert:
  • Candy Master
  • 11,904 Answers
Check gas pressure if ok possible blockage in burner tubes or pilot generator bad
Posted on Feb 14, 2021
Testimonial: "Good morning thank you for the advice but I live in Greece and we don't use gas but electricity mostly. ????"
1 Related Answer
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: CANDY OVEN
It will be the oven element that has failed, you need to fit a new one.
It is located at the rear of the oven compartment.
Posted on Feb 22, 2010
Testimonial: "GR8 JOB HAVE ALREADY SEARCHED ON THE NET BUT THIS CONFIRMS. NICE ONE CHEERS."
I cannot set the clock on my candy oven and I dont know the model number
The model number is usually on the side or rear of the oven.
Instructions for the clock are here:
http://www.manualsdir.com/manuals/243352/candy-fdp-231-x-uk.html?page=11
Nov 22, 2014 | Candy FP855 Electric Single Oven
How to find candy double oven model number
should be by the main oven door seal
May 19, 2014 | Candy Ovens
CANDY OVEN
Feb 22, 2010 | Candy F248P Electric Single Oven
How do a change the element on a candy oven , can't get to the old element
You have to gain access to the element by removing the outer rear panel of oven, if it is built in, then this means removing it from the housing.
Once you have removed the cover, and possibly the top panel, you will see how the element is fitted.
It is a fairly straight forward repair to do.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Candy F248P Electric Single Oven
Candy oven noisy fan
Noisy fan means bushes are worn. cant be repaired. needs replacement. Quote model of oven to spare parts supplier and replace. Make sure power is unplugged and not just switched off before repairs are done.
Sep 14, 2009 | Candy FP855 Electric Single Oven
Element needs replacing
You need to remove the outer rear panel of oven to gain access to heater on this model.
The element is attached to a panel at the rear of oven , which when removed gives you access to the element..
It cann ot be done from inside the oven.
Plz rate my solution.
Thanks.
Jan 24, 2009 | Candy Ovens
Ovens Logo
Top Candy Ovens Experts
Thomas Perkins
Thomas Perkins
ray gallant
Tom Chichester
Are you a Candy Oven Expert? Answer questions, earn points and help others
