Question about Refrigerators
Not displaying F for fault. Compressor feels hot, lines from it not hot. Fan working fine.
SOURCE: Freezer and Fridge side not cooling
Sounds like your Defrost heater is burned up. It is located in the back of the freezer compartment behind the lower cover. Look at the base of the condensor. Two screws hold the heater and two wire connectors. The heater is in a glass tube. Measure continuity from one end to the other, you should see a few ohms. if it is open, your heater is definitely burned. I got a good deal on a replacement heater on Ebay. I think it was $17 including shipping. The heater being bad will cause major frost buildup in the back of the freezer and stop the Ice maker from working and damage food. Be sure to thorougly dry the freezer compartment prior to putting it back in operation. If too much moisture is present, the new heater will evaporate the moisture into the Ice dispensoer motor and solenoid that swtiches from crushed to solid ice. Hope this helps. it has nothing to do with your problem, but please Check out my website www.playstationclinic.com
Posted on Sep 25, 2007
SOURCE: OVERHEATING COMPRESSOR
you can check its starting components. it could be a bad capacitor or a bad start relay. if the compressor starts from cold, it could start right away but as it heats up, it should be able to start also, since after running for a few hours, the compressor will really get hot, it would stop at defrost cycle and re start again after about 30 mins. since it is still hot, if it has a defective starting components, it can not start and that is the time it would overheat.
in any case that the starting components are all ok, then you have a partially burnt compressor. it would run while cold and can not run when hot because the resistance of the wires changes as it gets hot. with this kind of problem, you need to replace the compressor. as you have said, the fan at the condenser is running. if the fan at the condenser is not running, that is also a cause for the compressor to overheats. i hope i was able to help...
Posted on Jul 05, 2008
SOURCE: refrigerator Compressor hot to touch & fridge/freezer not cooling
you need to do an amp draw with your meter,clamp the run wire on the compressor,you should get 2-5 amp reading,any higher means the compressor is going bad,also should be a locked rotor amp(LRA) reading on comp.-mike
Posted on Nov 04, 2008
SOURCE: Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Posted on Jan 18, 2009
SOURCE: whirlpool gold GD25DF FRIDGE NOT COOLING FREEZER WORKING FINE
Clean out the coils at the very bottom of the refrigerator from all of that lint/dust buildup it makes your system inefficient
Posted on Mar 21, 2010
Jul 10, 2016 | Refrigerators
Sep 17, 2013 | Freezers
Sep 01, 2009 | Kenmore Refrigerators
Aug 27, 2009 | Kenmore Refrigerators
Aug 25, 2009 | LG Refrigerators
Aug 24, 2009 | Whirlpool GS6NBEXRQ Side by Side...
Aug 21, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Aug 19, 2009 | Whirlpool Refrigerators
Aug 18, 2009 | Refrigerators
Apr 02, 2007 | Samsung 26 Cu. Ft. Side-by-Side...
