CMD commands not working in windows 10?
When I run cmd and go to DOS none of the commands work ie ipconfig etc? Ran cmd prompt in safe mode sfc /scannow /scannow did a preliminary scan and then posted the following message "Windows resource could not perform the requested operation". Running the cmd prompt from windows as an administrator and entering sfc /scannow results in the following message "windows resource protection could not start the repair service" any ideas?
Posted by Artoria Pendragon on
jamessteerforth
    Habit-Forming:
  • 29 Answers
This issue can be caused by corrupted user profile and system files.
For us to better assist you, please answer the following questions:
Are you logged in to your computer as an administrator?
Can you tell us if you're getting any error messages when you try running cmd and running it as an administrator?
Does the issue also persists in safe mode?
You could use some common working solutions mentioned in this article:
[FIXED] Methods to Fix Command Prompt Not Working Issue
Posted on Jan 18, 2021
5 Related Answers
Anonymous
SOURCE: Channel 4 4oD doesn`t work with Flash Player!
Another one with the same issue!
Posted on Aug 23, 2008
leecom72
Lee Hodgson
  • 4810 Answers
SOURCE: My compaq Presario V6000 will
what you are describing is the blue screen of death, meaning theres a hardware or software problem, try to boot into safe mode and perform a system restore, if that doesn't work use your XP cd, let it load the drivers and the ask it to fix the existing XP installation, anything that you have saved in my documents should be safe and the problem should be solved. If the blue screen reappears then you have a hardware problem
Posted on Nov 13, 2008
rylee_smith
Rylee Smith
  • 8619 Answers
SOURCE: cannot get ip address from
Hi! Are you typing cmd in run (in start menu). If you want to check your ip address and can't see it through this way then open control panel, go to network connections, double click on local area network, then click on properties then click on internet protocol(tcp/ip) and then on properties tab, you would be able to see your ip add over there.
Posted on Dec 30, 2008
Anonymous
  • 116 Answers
SOURCE: windows xp shutdown after entering ipconfig, cmd on start-run...
could be a virus
do a system restore if possible to before the issue stated, then run a virus scan (maybe run an online scan in case your installed antivirus has been infected) something like housecall.trendmicro.com
If you cannot do a system restore in full windows, try it in safe mode (tap F8 during boot, select safe mode)
Posted on Feb 03, 2009
Keeter
Keith Killgore
  • 41 Answers
SOURCE: my (Win XP SP2) command prompt does not work
First off, lets try a few things. This will help us narrow it down:
  • Try typing other known commands to see if they work (ipconfig for example)
  • Do a search on your computer for cmd.exe (you should only have 1, and it should be in the system32 folder.)
  • try typing cmd.exe instead of just cmd.
Give those a shot and report back. Depending on which one of these give you a problem, it could point to the correct fix.
The reason I say this is that your easiest solution may be to upgrade to SP3. The only times I've ever heard someone having this problem was also in SP2.
Posted on Jul 27, 2009
I bought a packard bell pb1009 notebook but its asking for a pin code how can I unlockit?
IF it is windows 10:
Create administrator account for Windows 10 with command line As you've lost access to all your user accounts, you can't open a Command Prompt in Windows 10. Therefore, you need to get a Command Prompt and use command lines with the help of a Windows 10 setup/installation disc.
Step 1: Boot your PC from a Windows 10 setup/installation disc.
Tips: If you have no any Windows 10 disc, burn a Windows 10 ISO to a USB or CD/DVD drive to instantly create one.
Step 2: When you get to Windows Setup screen, press Shift + F10 to bring out a cmd.exe dialog. Then execute the following three command lines.
1. Type move d:\windows\system32\utilman.exe d:\windows\system32\utilman.exe.bak and press Enter to make a copy of utilman.exe file.
2. Type copy d:windows\system32\cmd.exe d:\windows\system32\utilman.exe and press Enter to replace utilman.exe file with cmd.exe file.
3. Type wpeutil reboot, press Enter, and disconnect the Windows 10 disc from the computer to reboot Windows 10.
Note: Replace d:\ with your system drive letter.
Step 3: When Windows 10 reboots up and comes to the sign-in screen, click the Ease of Access icon. This should open a Command Prompt dialog because you have replaced the Utilman.exe file with cmd.exe file in the second step above. Then execute the following two command lines to create a new admin account for your Windows 10.
1. Type net user /add [username] [password] and press Enter to create a new user account.
2. Type net localgroup administrators [username] /add and press Enter to add the newly created user account to your Windows 10 administrator group.
Sep 02, 2018 | Packard Bell Computers & Internet
Tip
CMD Prompt here, add to folder context menu windows xp
Add the open cmd prompt to folder context menus also drives and MY Computer
Copy what's in the code area to notepad and save as cmd here. reg
CODE
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\Drive\Shell\cmd]
@="Command Prompt"
[HKEY_CLASSES_ROOT\Drive\shell\cmd\command]
@="cmd.exe /k \"cd %L\ ""
[HKEY_CLASSES_ROOT\Directory\Shell\cmd]
@="Command Prompt"
[HKEY_CLASSES_ROOT\Directory\Shell\cmd\command]
@= "cmd.exe /k \ "cd %L\ ""
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\cmd]
@="Command Prompt"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\cmd\command]
@="cmd.exe /k \"cd %L""
on Jan 06, 2010 | Computers & Internet
Tip
Windows Vista password Recovery
If you have only one Admin account in Vista and have forgotten the password for the same and dont want to reinstall the operating system and land up loosing all your data, this tip is for you.
1) Restart the PC with the Vista Boot Disc.
2) Select Repair Your Computer option
3) Select the Command Prompt
Or - If you dont have a Vista Boot Disc then boot your PC to DOS using any Dos boot disk or other O/s disc.
4) goto "C:\"
5) Navigate to C:\Windows\System32 ( cd c:\windows\system32)
6) Now we will rename the utility manager to cmd.
Type the following commands,
- ren cmd.exe cmdold.exe
- ren utilman.exe cmd.exe
exit
7) we have renamed it successfully.
8) Restart the PC without the disc, reach the screen where you are asked for you password.
9) You will see a white blue icon on bottom left.
10) Click on the icon and CMD will open up, type the following command in CMD.
- net user administrator /active
exit
11) Restart the PC, and you will find you have one more administrator account
12) logon with the new account, goto user accounts and remove the password for your old account.
13) restart the PC with the Disc again, and goto the command prompt as we did in the step 1-3.
14) type the following command,
- cd c:\windows\system32
- ren cmd.exe utilman.exe
- ren cmdold.exe cmd.exe
15) restart the PC, and logon to your own account, open CMD by going from start menu.
16) type the following and restart the PC.
- net user administrator /active:no
17) restart the PC and now you only have one account and thats your own account.
on Dec 05, 2009 | Computers & Internet
I have sony vio laptop windows7 I forgot passwork ,How can i reset passwork thanks!
1. put windows 7 bootable dvd on your dvd rom
2. when you see the install windows screen type "SHIFT" + "F10"
3. now you can see the Command prompt (CMD) and type the following command
regedit.exe
Press "enter" key
4. now you get register edit window, after select File and click import
5. now you can see import registry file window
6. click computer and open c: drive on your registry file window
7. now open windows > system32 folder
8. change to " *.reg " to " all files "
9. now find and rename "sethc" file in to "sethc1"
10. now copy and paste the "cmd" file and you get "cmd copy"
11. rename "cmd copy" in to "sethc"
12. and close all open file and restart your computer
13. now after boot the windows you get password screen
14. after press " Shift " key continuously
15. now you can see CMD screen (dos screen) and type following command
net user
press enter key
now you can see user account on your pc (find out which account you need to reset password and type following commands
net user youraccountname 0
16. net user is dos command
youraccountbane is username
0 is (zero) new password
17. now closed CMD screen (DOS screen)
18. type 0 on you password box and enter
Dec 08, 2016 | Sony Computers & Internet
I want to change the password on my Acer aspire with windows 10
try this may be it works work for windows 10
regedit.exe
Press "enter" key
net user
press enter key
Dec 08, 2016 | Acer Computers & Internet
How to give test print through command prompt in windows-10.
you can print a test page from the command prompt using this command:
rundll32 printui.dll,PrintUIEntry /k /n “\\atl-ps-01\color-printer”
If you wanted to, you could wrap this command up in a VBScript and execute the test page from there. For more information about running command line tools from within a script take a gander at this classic Tales from the Script column (it’s actually the first Tales ever written
Jul 01, 2016 | Matrix Office Equipment & Supplies
Windows not genuine notification
Windows 7 not genuine notification using command propt How to make Windows 7 genuine using Command Prompt
Press Windows key + R
Now "run" box will appear , in "run" box type CMD
Click on OK
Note : Run CMD as Administrator
Now command prompt will appear
In command prompt type SLMGR -REARM
Hit Enter.
Wait 5-10 seconds
Now a message will appear as shown in image below.
Done !!!
Now your Windows 7 is genuine .. :D
Restart your PC once. Hereafter you won't see the warning message that "Windows 7 is not genuine"
Apr 05, 2014 | Microsoft Windows 7 Ultimate 32 bit Full...
How do i get my computer to let me in it keeps asking for a password to get by microsoft it comes up asking for a password but says i dont need 1 butand still will not let me in. help get me into my...
try doing system restore by tapping F11 if its Vista or F10 if its XP
or If you have only one Admin account in Vista and have forgotten the password for the same and dont want to reinstall the operating system and land up loosing all your data, this tip is for you.
4) goto "C:\"
exit
exit
Mar 20, 2010 | HP Computers & Internet
Keyboard stops working after password has been entered in Vista
Please follow steps below to reset your Windows Vista Password in 10 minutes.
Steps :
1. Insert the Windows Vista DVD into the DVD drive and then restart the computer.
2. Change Boot Options 1st Priority to Optical Drive.
3. When system booting up, if the message “Press any key to boot from cd” appears, immediately press Enter.
4. On Language Settings, Time and Currency and Keyboard Layout screen, just choose the correct settings then click Next.
5. On Install Now screen, click Repair. Note: Click No just in case you get the message: Windows found problems with your computer’s startup options.
6. On the System Recovery Options screen, under Operating System, click Windows Vista then click Next. Then select Command Prompt.
7. At the command prompt windows, type the following command then press Enter after typing each command:
c:
cd windows\system32
echo ~takeown /f %1 /r /d y > TakeControlOf.cmd
echo ~icacls %1 /grant administrators:F /t
ren Magnify.exe Magnify.old
ren cmd.exe Magnify.exe
8. Restart the computer.
9. On the Welcome Screen, click the Ease button.
10. Check Make items on the screen larger then click OK.
11. At the prompt, type the command then press Enter.
net user Administrator /active:yes
exit
12. Restart the computer.
Sep 27, 2009 | HP Compaq Presario CQ50-110US Laptop
Computers & Internet Logo
16 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
