Question about Electrical Supplies
N e only charging lamp n phone n speaker wuts the problem
SOURCE: Hello Tech Team: I own
Wow, you've got an ugly problem. It sounds like you already know that you have to pretty much disassemble these little buggers down to the frame to see anything inside, so I'll say what to look for:
1 - Burned wires in the part of the generator that doesn't move. This is the bit that carries the current shorted out by the mud.
2 - Burned wires in the part that does move. This is the bit that makes the magnetism that makes the electricity. There are also some diodes and MOVs tucked into the end of the plastic insulator
You're likley better off getting some other generator, sorry.
Posted on Nov 29, 2008
SOURCE: Question about Portable Generator
It will not even know it is working! Honestly, it will be a breeze for it!
Posted on Dec 22, 2008
SOURCE: 1000 watt Yamaha generator surges when on low setting
YOU PROBABLY HAVE LINKAGE PROBLEMS ON THE CARB IS IT AUTO THROTTLE IF SO YOU MAY ONLY NEED TO ADJUST THE SETTING SCREWS GIVE ME SOME DETAILS LIKE BRAND HORSE POWER CARB BRAND AND MODEL AND I MAY HAVE THE EXACT ANSWER FOR YOU I HAVE ALOT OF SMALL ENGINE RESOURCES FOR SPECS AND DIAGRAMS
Posted on Jun 24, 2009
SOURCE: voltage on portable generator is running high appx 135vac
What do you consider high? If the voltage is between 115- 125 volts, it's fine.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 02, 2009
Jan 31, 2015 | Electrical Supplies
Mar 31, 2014 | Buffalo Tools Sportsman Series 4000 Watt...
Mar 19, 2014 | Watts Onan Portable Generator - 4000 ,...
Dec 09, 2013 | Briggs & Stratton Briggs Stratton 6200...
Sep 08, 2013 | Watts Onan Portable Generator - 4000 ,...
Aug 05, 2010 | Watts Onan Portable Generator - 4000 ,...
Jun 05, 2010 | Watts Onan Portable Generator - 4000 ,...
Feb 05, 2010 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
Nov 01, 2009 | Watts Onan Portable Generator - 4000 ,...
Aug 23, 2009 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
18 people viewed this question
